  1. Yes
    74.2%
  2. No
    9.7%
  3. I Want One
    16.1%
  1. ivanhoe
    ivanhoe
    Northern Ontario
    pics would help on what you're trying to do!
    wildwest likes this.
  2. wildwest
    Thanks, it's still a stand alone right now, we are moving it to an adjoining room because of the fan noise, but here are diagrams.
    the tubes we brush:
    How do we access them if we install this? Does it need to be removeable?
    ivanhoe likes this.
  3. ivanhoe
    ivanhoe
    Northern Ontario
    Does the top grill unattached to gain access to clean?
    If yes then have the duct flex out of the way or lift up and swing away.
  4. wildwest
    Yes, the top grill is loose, not attached, the front grill is permanent. Would you explain what
    this means, specifically "swing away?
    Do you have heat exchanger tubes in your stove?
    ivanhoe likes this.
  5. ivanhoe
    ivanhoe
    Northern Ontario
    The heat exchanger tubes can be reached from the firebox and a removable panel in front for the Fahrenheit furnace. There must be a baffle to redirect the flow towards the top for the ductwork option. It might be with the ductwork kit mentioned above? I dunno!
    You got to setup yours in a way to move the attached ductwork out of the way to clean your tubes from above the stove which is what I understand. Correct me if I'm wrong....
  6. wildwest
    thanks for your help! I'll look into it further, yes, having to remove the ductwork to clean the tubes was my question.
    ivanhoe likes this.
  7. wildwest
  8. NorthernCrew454
    NorthernCrew454
    NE WI
    What kind of temperature deltas are you guys seeing with your units, between intake and outlet temp.
    ivanhoe likes this.
  9. ivanhoe
    ivanhoe
    Northern Ontario
    I'm not pushing mine anymore, T-stat #3. I don't do the temp in, my HRV fluctuates the inlet temps and plays with my outlet temps.
  10. ivanhoe
    ivanhoe
    Northern Ontario
    I found another bug in the CB, no vacuum/no POF showing on the LCD board and my auger started to feed pellets :eek: My start-up is in Manual and not in Auto Ignition.
    I had to restart it to do a pot change if you get my drift ;) I was cleaning the stove when this happened( no fire and doors open) :whistle:
    I also added a 2-way toggle switch for my distribution fan so I could run the fan at 600cfm instead of 800cfm, now I have a choice of both at my fingertips :thumbs:
    jtakeman likes this.
  11. Jerry Welch
    Jerry Welch
    Indiana
    I need to replace my auger motor it is starting to get loud but I am not sure what RPM it is so don't know which one to purchase, can anyone help me with that and maybe a good place to purchase it please.
    ivanhoe likes this.
  12. ivanhoe
    ivanhoe
    Northern Ontario
    It can be just a added lube to the gearbox, cheap fix! It's a 2 rpm.
  13. Jerry Welch
    Jerry Welch
    Indiana
    Thanks Ivanhoe
    ivanhoe likes this.
  14. Jerry Welch
    Jerry Welch
    Indiana
    I have a question, I am in need of a flapper door assembly that goes in front of the burn pot or try to make my own if the latter is the case I need to know what type of stainless it is made out of, any help from you guys would help greatly.
    ivanhoe likes this.
  15. ivanhoe
    ivanhoe
    Northern Ontario
    What's worn out on the flapper door assembly? I had to remake the burnpot side of it and decided to use 1/4" SS instead of the 1/8" original. If you look back a year or more in this thread you will find the info. Off my head of which SS I used? Maximus can make one up for you along with the whole burnpot. In the mean time, I'll look for the thread...
  16. Jerry Welch
    Jerry Welch
    Indiana
    It is the pivot pins on each side they just fell out and the metal they was welded into is less than an 1/8" thick
    ivanhoe likes this.
  17. ivanhoe
    ivanhoe
    Northern Ontario
    Ouch! You might be able to use some stainless bolts tacked into place. I got to take a look and see what you can do. I'm in a deep freeze this week, might be a little while to knock the furnace down. If you can take a few pics, I'm sure we can come up with something! You can bring it to a welder and scratch his head :smoke:Are you burning 100% corn?
  18. ivanhoe
    ivanhoe
    Northern Ontario
    Did a fast LBT clean before the cold snap and checked the burnpot assembly, those pins are made of steel and not stainless. Tacking bolt heads should work.
    Happy Birthday NorthernCrew454
    CleanFire likes this.
  19. Irish-1
    Irish-1
    Victory Twp,Mason County,Michigan
    Been Awhile since ive been on,Just wanted to say Hi to everyone, The Stove been working well,Ivanhoe would be proud,got the output temp up to 185*!:smoke:.
    CleanFire and ivanhoe like this.
  20. ivanhoe
    ivanhoe
    Northern Ontario
    What are you burning in that furnace, volatile canola seeds? Impressive :DWhat are your settings at?
    CleanFire and jtakeman like this.
