  1. Yes
    74.2%
  2. No
    9.7%
  3. I Want One
    16.1%
  1. ivanhoe
    ivanhoe
    Northern Ontario
    Looking at the reassembled pot assembly there's a gap opening at the bottom which is not a good thing! I wonder how is a regular one is like as I didn't notice it before tampering with it. I made sure the measurements were pretty much the same. I will weld a extra piece to cover the gap.
  2. Irish-1
    Irish-1
    Victory Twp,Mason County,Michigan
    When I get home tonight i can snap a pic of my factory one so you have a reference.If that would help ya out
  3. ivanhoe
    ivanhoe
    Northern Ontario
    That would be helpful :handshake:
  4. Irish-1
    Irish-1
    I am so sorry Ivanhoe,I been side tracked..working a bunch of hours..Ill get those photos to ya.
  5. DexterDay
    DexterDay Administrator
    Northeast Oh
    That's exactly how mine is. I used furnace cement to make a seal. But I have to replace the cement every year
    ivanhoe likes this.
  6. ivanhoe
    ivanhoe
    Northern Ontario
    I weld tacked a metal sleeve and will high heat silicone the crack. Loosing a lot of air is not a good thing :eek:
  7. Irish-1
    Irish-1
    better late than never...lol
    ivanhoe likes this.
  8. ivanhoe
    ivanhoe
    Northern Ontario
    Much better fit, Thank you for taking the time :handshake:
    Irish-1 likes this.
  9. ivanhoe
    ivanhoe
    Northern Ontario
    Here's the pics of the modifications :salute:
    Irish-1 likes this.
  10. Irish-1
    Irish-1
    Like I said before sorry it took me so long.I Have mine up and running in Fuelmiser mode,supposed to snow this weekend!
    ivanhoe likes this.
  11. ivanhoe
    ivanhoe
    Northern Ontario
    I need to adjust my bottom actuator as my burnpot isn't lining up with the dump door mechanism tabs o_O I'm off about 1/8", oh well such is life :picard:
  12. Irish-1
    Irish-1
    Better to deal with now than later!:) I've have a new fasco with the bigger impeller im going to install this weekend,After I give it some epoxy love,And i'm also extending my chimney outside to make it taller,and if I have time a new 3" fresh air intake. :thumbs:
    ivanhoe likes this.
  13. ivanhoe
    ivanhoe
    Northern Ontario
    You're gonna like the extra air boost and don't forget to re-adjust your air damper back some. What's up with the chimney? The fresh air intake is very beneficial so make time ;)
    Irish-1 likes this.
  14. Irish-1
    Irish-1
    My Chimney comes out of my basement wall and only has 14" of clearance to the ground,I want to get it up so the wind will get the exhaust away from the house.
    ivanhoe likes this.
  15. ivanhoe
    ivanhoe
    Northern Ontario
    Here's a pic of my extended bed on my truck with 1000kg of corn to be unloaded into the drums. All done before the wintery blast last night!
  16. chbryson
    chbryson
    Well the cold weather kinda snuck right up quick this year and I did none of my spring maintenance or fall before firing up the stove with what was left inside it from the spring. So far this year, just about every day I come home the stove is shut down in some error.
    Last week:
    Auger time out error (lid switch is already bypassed due tot he extended hopper on my stove
    No Vacuum error (seals were so bad and exhaust was clogged up a bit)
    Smoke smell throughout house at 3 am (quite a little excitement for a while thinking the house was on fire and the smoke detectors all quit working. Turns out prior to fixing the door gaskets, the stove would let a puff of smoke out of the combustion area into the main housing every couple of seconds then blow that smoke through all the ducts. Now the whole house smells like my camp with a regular open fireplace... wifey loves it...
    This week:
    Actuator limit errors every couple days. Time for another deep clean and make sure everything is just right on the burn pot assembly and not binding up.
    Can't quite get the exhaust pipe to seal onto the exhaust blower out the back (bottom side won't quite seal just above where the sheet metal housing and intake pipe almost touches exhaust pipe and I can't get it to seal with high temp silicone (old tube that won't spread well and can't reach with foil tape, plus need to be a contortionist to get to the area with where my stove is located in the basement. So the intake air is sucking the slight amount of smoke from the leaky exhaust back into the stove.
    Up until this year, the stove has been great, my lack of preventative maintenance is making me feel like an a@!
    Irish-1 and ivanhoe like this.
  17. ivanhoe
    ivanhoe
    Northern Ontario
    Unlike:confused:
    You're having a great start to the season :eek:
    Irish-1 likes this.
  18. heyswitz
    heyswitz
    skunks mizery ontario
    hey ya,ll just check,in in everyone ready for the white stuff down by chatham on, an we got about 3in today don,t have my corn for the season yet farmers don,t have much picked an dried hope all do,in well let the fun begin!
  19. Irish-1
    Irish-1
    Im happy to report extending my chimney up 5' straight up has made an improvement! Also installed a 4" fresh air intake to the back of the stove,She is rock n roll now! :yes:Next up is the new quiet combustion motor with bigger impeller and 'ill make some new high temp silcone gaskets. Just got hammered with 16" of fresh snow last night!o_O
    ivanhoe likes this.
  20. heyswitz
    heyswitz
    let us know how the new propeller an motor works I may do the same!
    ivanhoe likes this.
