Cathedral ceiling install
Discussion in 'Modern EPA Stoves and Fireplaces' started by chance04, Oct 17, 2017.
  1. chance04
    chance04
    Denton Md
    So I tore down the old lined cement block heatsink and am in the process of installing dsp and class a chimney. I have selkirk class a already so i purchased selkirk 206621 and the flashing for my roof. My question is am I going to have to get one of those black support boxes or do I just cut back the clearances and use the trim?
    Sent from my SM-G900V using Tapatalk
  2. OhioStihl
    OhioStihl
    Southern Ohio
    Black support box for cathedral ceiling.
  3. chance04
    chance04
    Denton Md
    Do I fab one or how does that work
  4. OhioStihl
    OhioStihl
    Southern Ohio
    I'm not sure what comes in the 206621 kit. When I have installed through the ceiling chimneys I used all purchased items and installed per instructions. I didn't have to fabricate anything. I even used the supplied trim kit to trim out the black box that went through my ceiling.
  5. chance04
    chance04
    Denton Md
    206621 doesn't include a box. It's a adjustable class a section with nailing wings that are movable to adjust to the pitch of your roof. Since I only penetrate the shingle, sheathing, 2x6 rafter, and 3/4" tongue and groove ceiling. According to northline express the kit includes everything except the flashing
  6. chance04
    chance04
    Denton Md
  7. chance04
    chance04
    Denton Md
  8. OhioStihl
    OhioStihl
    Southern Ohio
    I spoke out of my Dura Vent experience. I'm not sure on the Selkirk. I always have used a box in the ceiling, maybe Selkirk is different
    chance04 likes this.
  9. chance04
    chance04
    Denton Md
    And don't get me wrong, I'm not trying to argue. I'd just like some positive reinforcement before I go cutting holes in my new roof only to find I have to go back to fix/repair/correct/or buy more parts before i can get to choochin lol
  10. OhioStihl
    OhioStihl
    Southern Ohio
    I completely understand, the hole in the roof is a big pucker factor. Does Selkirk have a tech support number?
  11. chance04
    chance04
    Denton Md
    I'll look that up, I guess I could email their tech support as well
  12. Kimberly
    Kimberly
    The Kangaroo State
    Looking at Northline it is called a pitched ceiling support kit (206621) and their description states:
    For installation of a chimney in a cathedral or pitched ceiling such as standard A-Frame construction. The Pitched Ceiling Support Kit provides all necessary parts for a complete installation with the exception of the required Insulated Pipe Lengths and Adjustable Flashing. Note: This kit includes a stove pipe adapter that will only work with single wall pipe stove pipe. If you are planning on installing double wall stove pipe you will need to also purchase 5SE-6DSP-CPA to ensure that you will be able to install this kit.
    PDF of the instructions http://www.noutilitybills.com/PDF/Selkirk/CF/CFRoofSupportedChimneyInstall.pdf
  13. chance04
    chance04
    Denton Md
    I read all that and was told I'd still need a support box, which went against what northline said and now I've contacted selkirk and they confirmed flashing is the only extra part I'll "need" to purchase that wasn't included in the kit.
  14. chance04
    chance04
    Denton Md
    Piece of mine has been gained. Thank you to all
  15. Kimberly
    Kimberly
    The Kangaroo State
    Yes, you will be good to go. Here is to happy hunting.
