Whats difference between: MS-362, 362 C and 362-CM ?
Discussion in 'Chainsaws and Power Equipment' started by Machria, Oct 28, 2014.
  1. Machria
    Machria
    Long Island, NY
  2. lukem
  3. Machria
    Machria
    Long Island, NY
    Not anymore! Got 1.2 cord out of it... BUT, it did make for some really ugly/twisted/knotty splits. ;)
    Deacon likes this.
  4. Moparmyway
    Moparmyway
    New York
    How do you like that splitter ?
  5. Machria
    Machria
    Long Island, NY
    Love it! Haven't hit anything it didn't split. This big maple this past weekend had some big really twisted knotty crotches, I thought a few would give it a problem but she man handled them. But the best thing about this splitter is the work area, no tires, no axel, no nothing in the way to stand and work or to be hit with falling splits. Control is center mounted so you can work form either side, auto return, log cradles on both sides, and I added the work table which is really nice. It's got the smallest footprint of any available H/V splitter I could find. Storage space is premium at my place.
    The motor starts right up 1 or 2 pulls, the only thing I don't like is it hunts once in a while. Almost like it can't get enough fuel...
    Moparmyway likes this.
  6. MasterMech
    It probably can't.
    Carburetors are set lean (non-adjustable) from the factory. Lean enough to pass emissions with Ethanol free fuel. Running E10 in it makes it even leaner (less fuel) so you may get the occasional surging under no-load conditions. The amount of Ethanol in pump gas varies from 0 to 10% (perhaps beyond that) plus weather conditions affect carburetor tune so that's why the surging only happens part-time. Find you some ethanol-free fuel to run (boat marina?) and I bet the surging stops.
  7. Machria
    Machria
    Long Island, NY
    Thanks,, I'll try that. Probably doesn't help I added a fuel drain to the fuel line via a "T" and second shutoff after the T.
  8. MasterMech
    The drain isn't hurting anything.
  9. Machria
    Machria
    Long Island, NY
    I was referring to the fact I may have restricted the line a bit with the T, L connector.... but I also doubt that's causing an issue.
    Since we are talking fuel... what octane fuel do you recommend running in the splitter? Would a higher octane make it worse?
    AND, same for saws? 87, 89 or 91...?
  10. Moparmyway
    Moparmyway
    New York
    IMHO, anything without ethanol is best ..............
    If you find anything please let me know, as I have resorted to VP
      File size:
      410.9 KB
      2
  11. Machria
    Machria
    Long Island, NY
    I do not know of anywhere you can get e free fuel on LI! I don't think you can. Marine fuel on LI has e in it unfortunately. The Outboard mechanics have spent that last 3 years cleaning out peoples carbs and fuel systems on Yami motors that can't hande it at all.
  12. Moparmyway
    Moparmyway
    New York
    I sure havent found anything at any pump other than 118 low lead
    The VP is the cheapest way for me to run E-free .............. I just add some oil to get to 32:1
  13. Machria
    Machria
    Long Island, NY
    "VP"? and "118"?
    And it will NEVER be at a pump in NY, it's illegal for ANY purpose in NY. Some states have provisions for stuff like marine.... but not NY.
  14. Moparmyway
    Moparmyway
    New York
    VP (post#150) in a 5 gallon can. Grainger has them.
    118 is Cam 2 race gas. 118 octane, low lead.
    Good old NY .............. I cant get my daughter physical therapy, insurance wont cover it :mad: - she just got a cast off her arm (wrist to upper fore-arm) .............. but if she wants a sex change, that's covered. :jaw:
    MasterMech likes this.
  15. MasterMech
    The lowest octane you can run without issues is the way to go, all things being equal. I've run 87 for years with no trouble in everything from the weed wacker to the pickup.
    For you guys that have the option, if premium grade fuel in your area is E-free then by all means go that route.
  16. Machria
    Machria
    Long Island, NY
    I thought I read in the Stihl manual they recommend 93 octane? Or am I remembering it from something else? I read it somewhere recently...??
  17. MasterMech
    They officially spec 89 octane because mixing the fuel with oil lowers the octane rating just a gnat's azz. Most fuel is a bit higher octane than its labeled to be. The labeled rating is a minimum, not an absolute.
    Kg461 likes this.
  18. Kg461
    Kg461
    Provencal, La.
    I mix a gallon of fuel half with 87 e free and Sunoco 110 with 4oz of motul 800t at 32:1. That has treated me well but I agree with MasterMech that the lower octane burns more completely and with a tad more energy​
  19. Machria
    Machria
    Long Island, NY
    Yea, I "LOVE" [insert sarcasm here!] our great state of NY too! Thanks for the Grainger tip, I'm going to give that a shot.
