Kubotas at play. Er, I mean work!
Discussion in 'Chainsaws and Power Equipment' started by Warner, Jan 20, 2018.
  1. Canadian border VT
    My brush bull is 6' no rocks.. But the swamp is tooo wet
  2. eatonpcat
    Rocks on sharp blades will definetly make you pucker!
  3. mike bayerl
    mike bayerl
    Moving a little lumber around with the pallet forks today. Dodging chickens, sheep, dogs, etc. 20190810_160617.jpg 20190810_153434.jpg
    Chvymn99, Flamestead, Thor and 6 others like this.
  4. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I am just finishing up the 50 hour service on my Kubota. The front axle oil wasn’t due but a Kubota mechanic said it was a good idea. I saw a video on YouTube and the guy put aluminum foil on the wheel to keep them clean. That worked out well.
    D75B41C8-6109-4C9A-9937-44D761298C70.jpeg A4544FF9-AFBE-4012-8A0F-6C01CE663E9D.jpeg
    Chvymn99, Flamestead, Thor and 8 others like this.
  5. Well Seasoned
    Looking good! Was doing the same thing yesterday, but the chickens were dodging me! :tractor:
    Chvymn99, Thor, Chaz and 5 others like this.
  6. Well Seasoned
    Nice job!
    You used the bucket lock? Curious what the 2x4 was used for?
    Did you have the wife use a shop vac to keep the trans fluid in place while you swapped out the filters?
  7. Jack Straw
    Jack Straw
    The 2x4 was to keep the loader arms from falling on me. Is there a lock? No! I didn’t know about the shop vac! Very expensive filter change :picard:
  8. Will C
    Will C
    New York
    I was dubious, but that shop vac trick really works. I used it when I did the 50 hour service last summer.
  9. Well Seasoned
    Yes there is a lock, but it's mainly for the control shaft. Should be right underneath. Good on you for added safety.
  10. Will C
    Will C
    New York
    I always use the lever lock, but that 2x4 is a great idea. I often use the FEL to lift my mowers for service, and know I should be safer-that 2x4 trick looks like a good simple way to do so.
  11. Jack Straw
    Jack Straw
    I took the bucket off also.
  12. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    That 2x4 isn't going to do squat. Sorry to rain on your parade. If that bucket falls due to a hydraulic line failure, it is going to come down so hard and so fast, it will snap that 2x4 or create such a ruckus that clamp will be knocked off. To make a safe easy fail safe situation, do you see where the ram is coming out of the cylinder? then to the end of the ram? Measure that distance and cut a piece of angle iron, using a hose clamp put the angle iron against the ram in that space, lower the bucket until all pressure released and the angle iron is holding the bucket. Now you have a mechanical lock. Even jack stands, if the item being worked on isn't lowered to the stands and checked for stability, you aren't safe under something with them under there. Jack stands and locks don't "catch" falling items, they mechanically lock it in place. So for using your bucket for working on lawn mower, cut a piece of angle iron for the distance your bucket is up and then you also will be safe. Hydraulics are wonderful tools, but they are patient like all tools and wait for us to become complacent. Okay, will step off of the podium now and back to your regularly scheduled programming. :)
  13. T.Jeff Veal
    Great idea. I need to do that, as we use loader to pick up mower also.
  14. Well Seasoned
    Spent the last couple hours bringing loads of staymat down to the pole barn. Will continue tomorrow.
    fuelrod, Thor, Chaz and 6 others like this.
  15. Jack Straw
    Jack Straw
    That’s awesome! Is there a build thread?
  16. Well Seasoned
  17. tree killer
    tree killer
    Central me
  18. Well Seasoned
    Nothing more fun than running material! Take a road trip up Mt.Wash?
  19. tree killer
    tree killer
    Central me
    Been in Vermont working, have to work here tomorrow 15 minutes from home at 8 am. Sad thing is I've been through Conway 3 times in the past week and I hate going to Conway. Came from southern Maine yesterday and took 302, that ride was horrible being the tourist season. I'm really not sight seeing I got work to do.
  20. Well Seasoned
    I probably passed you on 302. I'll be in twin mt & Northumberland tomorrow.
