Idea for wood stove in uninsulated, unfinished basement
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by KeswickRidge, Feb 18, 2020.
  1. Eric VW
    Settle down.
    Only warning.
  2. BHoller
    BHoller
    Central pa
    To the op if you are set on heating from an uninsulated basement go with a highly convective stove. Because with convective heat will loose a much lower percentage of your heat to those floors and walls.
  3. yooperdave
    The OP has a already installed ductwork system which will be much more effective in distributing heat throughout the house. Not the best looking distribution system for sure, but better than overheating the basement in an attempt to heat the house.
    The OP also posted in another sub forum which is why I provided the link.
  4. BHoller
    BHoller
    Central pa
    Yes and the op clearly said they wanted to get rid of the furnace and install a regular stove. Which cannot use the duct work.
  5. yooperdave
    Did you click onto the link and read the entire thread?
    Idea for a wood stove in an uninsulated/unfinished basement.
    Looks like OP is re-considering his original intent.....
  6. BHoller
    BHoller
    Central pa
    Yes possibly reconsidering. I see that but I am simply giving advice on the question posed here. And no I didn't follow the random link you provided with no explanation until you said what it was. If you had explained the link the first time it would have been helpful
