I got a leaner!
Discussion in 'The Wood Pile' started by cigarsmokingzombie, Nov 23, 2019.
  1. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
  2. cigarsmokingzombie
    cigarsmokingzombie
    Delaware
    I hope to redeem myself V 2.0. When there’s a bust, you really wanna go overboard on the ordinance. Then I blow my windows out. I’m hoping for a happy medium :)
  3. Brandon Scott
    Brandon Scott
    If yer gonna be a bear you might as well be a grizzly!
  4. Chaz
    Chaz
    Southwestern NY
    Just remember, he's gotta deal with Mama Bear.
    :heidi:
  5. Brandon Scott
    Brandon Scott
    Being a single guy I sometimes forget that.
  6. Diesel 4 life
    Diesel 4 life
    Kansas
    You could always get some plywood for the windows when your at Home Depot picking up the 5 gallon bucket. :thumbs:
  7. JB Sawman
    JB Sawman
    pennsylvania
    Thats why they used the tannerite you could not cut your !@! if you sat on that saw :rofl: :lol:
  8. jo191145
    jo191145
    Ct
    As someone mentioned in this thread. It’s all about direction of force. Essentially the tree becomes the base the explosion deflects off of but receives very little force itself. Much like the shaped charge of a claymore mine.
    Unless you can insert it into a hollow tree this exercise gets difficult. Basically the only chance of success is a tree so severely weakened already it’s ready to topple.
    With tannerite it’s difficult to shape a charge in reverse of the direction of fire. Bullet has to make it to target which is right through the path of any attempt to shape the charge. Not to mention that would send shrapnel of the shape right back at the shooter.
    I would suggest two pounds of tannerite. One bottle directly in front of the other. The first bottle will explode a millisecond before the one behind it. This should have the effect of at least minimally forcing the explosion of the second bottle to direct part of its force against the tree. Instead of weight your using explosives to shape the charge. No shrapnel.
    Also because your now toying with direction of blast accuracy becomes paramount. You may want to get that 5.56 sighted in dead zero. Need to hit that bottle dead center to achieve best results. Just going boom is no longer the only objective.
    Good luck, keep us informed of the entertainment.
    Thinking on it a minute. 4lbs in a diamond shape would work much better. 3 lbs directing the last pound directly into the tree ;)
    morningwood, Chaz, FatBoy85 and 9 others like this.
  9. Cheepbeer
    Cheepbeer
    NW Ohio
    I’m not an explosives expert either, but I stayed in a holiday inn express 20 years ago. A buddy of mine was a powder monkey in the stone quarry. He always directed the blast by packing mud on the opposite side. The mud absorbs the shock on that side. Since you’re obviously not a marksman, it’s gonna be hard to set it off.
  10. MikeInMa
  11. WeldrDave
    :eek:o_O
