Coleman Generator find
Discussion in 'Chainsaws and Power Equipment' started by WeldrDave, Jun 30, 2018.
  1. WeldrDave
    Yes! so far so good, it stays/comes back at RPM when load is applied.
  2. brenndatomu
    Gennys get their speed adjusted with a HZ meter...many multimeters have a setting for it. In the USA they get set to 60HZ...other parts of the world use 50HZ.
    The voltage regulator should hold somewhere 115-125V at 60HZ
    EDIT: on a small single cylinder powered genny like that you could also set the RPM to 3600 with a tach...that will be 60HZ on the genny.
    Chaz, amateur cutter, Camber and 3 others like this.
  3. WeldrDave
    I'll look to see if I have a HZ reading on my meter. I didn't check that, Thanks!:yes: I know when I used to regulate the generators on shipboard, we used to dial in the HZ. Thank you for that reminder, I had totally forgot it. o_O
    Chaz, amateur cutter, Eric VW and 2 others like this.
  4. Eric VW
    Age.....ain’t it a b!tch......:doh:
  5. WeldrDave
    Today my friend from the CG base who is the high voltage electrician came by with a multi meter that looked like the instrument panel to the space shuttleo_O:confused: and we ran the generator. On initial start up, it finally settled in at 59.36 HZ so we kicked the RPM up a tiny bit so he got it at 60.21 +- a few ths. We loaded it up with a heat gun, and the halogen lamps and it stayed between 59.80's and 60.09+- He said he was satisfied and it will fluctuate a little but for "most stuff", Lights, tools, it'll be fine. :) I think it's in the game now
  6. brenndatomu
    Sounds like the ole girl is ready to report for duty! :salute:
  7. MikeInMa
    Can't complain about space-shuttle ready!
    Chaz, WeldrDave and brenndatomu like this.
