How often do you clean the stove glass?
Discussion in 'Modern EPA Stoves and Fireplaces' started by saskwoodburner, Jan 17, 2017.
  1. HDRock
    Maybe this will help you
  2. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I think I cleaned mine back in February. Probably do it again soon so I can see the secondary flames.
    bear 1998 and saskwoodburner like this.
  3. Richcode
    Richcode
    Oceanside NY.
    Thanks i thought it was something like that cool air across the glass , Lopi stoves seams to be one of the better designs for clean burning
    bear 1998, HDRock and brenndatomu like this.
  4. Richcode
    Richcode
    Oceanside NY.
    i only get secondary flames when i close off some of the primary air and then the glass gets scooted up and
    if you open the primary full open and run a hot fire it clears up and easy to clean
    bear 1998 likes this.
  5. ReelFaster
    ReelFaster
    S.Jersey
    Funny you mention that, I find myself just staring at the fire and rolling secondaries and not even paying attention to the TV.......
  6. BDF
    BDF
    Why do you think it took our ancestor 200,000 years to get to our current point? They took way too much time sitting and watching "fire" and were entranced by it to bother to build roads, buildings, etc. etc., ad nauseum. When they finally found out you can actually bring fire INTO THE HOUSE, mankind began to advance.
    Brian
    moresnow, bear 1998, Maina and 4 others like this.
  7. MightyWhitey
    MightyWhitey
    Once I finally reached Nirvana; and CSSed my way way to 3 years ahead on wood, I only need clean the glass MAYBE on my 13NC about halfway thru the burning season...............and then when I shut the stove down for the warm months.
  8. Hullspeed
    Hullspeed
    Maryland
    I've got a Lopi Freedom. Maybe the air wash does something (?), but it didn't keep light ash from building up on the glass. I don't have any complaints, but it doesn't do anything magic. I clean the dust off my glass once every day or two as time permits.
  9. Canadian border VT
  10. Marvin
    Marvin
    Huntingdon, Pa
