Season Ending Cleaning
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by BHags, Sep 13, 2017.
  1. BHags
    BHags
    Massachusetts
    So, as usual, my season ending stove cleaning has become my season starting stove cleaning! I hate to give it that good cleaning if I might need to fire it up again. I replaced the air exchange scraper rod. It comes without hardware, so I needed to find two bolts, one before the scraper, and one after. No big deal. I pulled all the motors out and hit them with the air compressor, so I needed to replace the exhaust fan gasket. The inside perimeter was too big, so I had to cut it down about a 1/4 inch. Pulled out the leaf blower, pipes are clean as new. Everything is greased and ready to go. Natural it is unseasonably warm today, in the eighties, so I wont be firing it up! My back hurts, and I look like a coal miner. It better be cold this winter.
  2. ivanhoe
    ivanhoe
    Northern Ontario
    My cleaning schedule is pretty well the same has yours only I haven't got around to it yet:doh:
    I've been using the stove last week and will be soon enough so I won't clean just yet:whistle:
    Plus I don't want to look like a coal miner:rofl: :lol:
  3. subsailor
    subsailor
    Winthrop, Maine
    You guys aren't alone.:emb:
  4. jtakeman
    Me 4............
    Haven't touched it since June and likely won't until its burn time again. :emb:
    :shiver:
    :heidi:
    CleanFire, Russell, BHags and 4 others like this.
  5. Pete Zahria
    Pete Zahria
    New Hampster
  6. MtDew
    MtDew
    Perkasie, PA
    Me x 6!
    CleanFire, Russell, BHags and 3 others like this.
  7. slvrblkk
    slvrblkk
    Northampton, PA
    Slackers! :rofl: :lol:
    CleanFire, gbreda, Russell and 7 others like this.
  8. jtakeman
    Ehh hum, I expected 6 pellets test by now..... :whistle:
    :p
    JK!! :D
    CleanFire, gbreda, Russell and 3 others like this.
  9. slvrblkk
    slvrblkk
    Northampton, PA
    :whistle:
  10. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    i did mine last weekend.... same reasoning aswell
    CleanFire, Russell, BHags and 2 others like this.
  11. schoondog
    schoondog
    Dutchess County N.Y.
    numero seven
    CleanFire, Russell, ivanhoe and 4 others like this.
  12. Earl764
    Earl764
    CT
    Just need to pull the baking soda.
    CleanFire, gbreda, Russell and 4 others like this.
  13. will711
    will711
    Pocono Mts.
    I seem to recall that you just cleaned your stove recently too :whistle::whistle::rofl: :lol::rofl: :lol::rofl: :lol:
    CleanFire, Russell, ivanhoe and 2 others like this.
  14. slvrblkk
    slvrblkk
    Northampton, PA
    :whistle:
  15. jtakeman
    :eek:
  16. Russell
    Russell
    South Coast , Massachusetts
    I waited one year and found rust already forming and the ash lining the stove damp . Now at the end of the season I capped off the vent , go right through the stove , touch up inside with Rust-Oleum and add Damprid .
  17. Woodporn
    Woodporn
    S. MA
    Did my preseason cleaning last week and found rust in my burn pot/baffle....nothing a wire wheel and running it for an hour couldn't solve
    Was 75 outside and I'm the only fool for miles with a pellet stove running in the driveway!
    Hey does anyone have a trick or know of a way to cut Selkirk pipe to size? I need to reduce my horizontal run by about 3 "
    CleanFire, Russell, gbreda and 2 others like this.
  18. jtakeman
    I don't think they recommend cutting or modding the pipe. Don't they make an adjustable piece?
    CleanFire, Russell and slvrblkk like this.
  19. Woodporn
    Woodporn
    S. MA
    They do but IIRC it's minimum it still too long. I think its a 12" piece that adjusts down to 8 on a straight run, I have one between my stove adapter and the first elbow (45)
    CleanFire, jtakeman and slvrblkk like this.
  20. jtakeman
    You might be able to trim that one down. The ID and OD of that piece is made to slip inside one and other. Your standard pipe has the same ID/OD and won't slip together. It would require special dies to fab the end joints to mod the pipe itself.
    I've trimmed an inch off the Pellet vent pro adjustable piece with out an issue. Just had to smooth off all the burrs from cutting it(used a die grinder) so it would slip back together easily. Assume the Selkirk would be the same??
    CleanFire and Russell like this.
