References to charcoal
Discussion in 'The Smokehouse' started by FatBoy85, Sep 12, 2017.
  1. FatBoy85
    FatBoy85
    Lakewood Washington
    After I tried a hand at this, I've Been wanting to make my own charcoal in larger amounts. The barrel method works but the vessel itself is not as air tight. Really I finangled two kerosene barrels together 5 gal, and the heat may have been a bit much for the gauge. Started flaking off so I need to find something that will work better.
    I do have something but its holding wood right now.
    The reason why I am asking to make charcoal and get some pointers is to know likely what wood is to make charcoal for cooking and which is for say forging. I have black locust and some say this is good for charcoal but others say not for food. So which is which?
    wildwest likes this.
  2. Canadian border VT
    I think it's clemsonfor that's has most knowledge on this
    wildwest and FatBoy85 like this.
  3. saskwoodburner
    saskwoodburner
    Prince Albert, Saskatchewan, Canada
    I'd just make charcoal out of whatever wood you might smoke with/ cook with to be safe. But that's a "guess", not a "know"
  4. FatBoy85
    FatBoy85
    Lakewood Washington
    My supply of oak is moderate to my taste. I feel comfortable with the anount of wood I tend to collect. Its something to play around with as well. While the oak is not seasoned per se, I wonder if this could be a blessing in disguise. When I made the charcoal at first, it made that Jet like noisr as the smoke turned to flame. But really the MC content may help keep the fire under control inside? Introspective thoughts here...
  5. bocefus78
    bocefus78
    Indiana
    lukem has done this.
    Lukem, please pick up the courtesy phone
    FatBoy85 and wildwest like this.
  6. lukem
    I have a food grade 25 or 30 gallon metal drum with a lid. I fill this with 2" - 3" wide pieces of hardwood...hard maple and hickory mix is my favorite. Length doesn't matter as long as it fits in the drum....it breaks up easily later. More than 3" wide doesn't "cook" enough on the inside.
    I have a 55 gallon metal drum with the top and bottom cut out. Does not need to be food grade.
    Set the small drum on the ground and put a brick on the lid. The lid shouldn't be tight....place 3 or 4 bricks around it and set the big drum over the top and around it...held off the ground by the bricks to create and air draft.
    Fill the gap between the two barrels with anything flammable. Branches, scraps, cardboard, whatever, and burn for 2 or 3 hours. When the smoke escaping froom the lid turns clear and/or no longer flares off...its done.
    Leave the lid on overnight....if you take it off too early the oxygen will set it on fire and you loose your charcoal.
  7. lukem
    I've made charcoal from oak, maple, hickory, and some hedge just for fun. Hedge charcoal could run a forge....but barely.
    FatBoy85 likes this.
  8. Jon_E
    Jon_E
    Southwestern Vermont
    I cheat.
    I just dig a couple shovels full of coals out of my outdoor wood furnace every so often, and dump them in an airtight galvanized can. Does not take long to accumulate quite a hoard of charcoal. I do try to fill the firebox with species that I normally would cook over - favorites being maple, beech or cherry. Although by the time it's become charcoal, there isn't much in the way of wood smoke flavor left. It's just heat that that point. Which is why most people cook over compressed sawdust/chemical cakes a/k/a briquettes. So any good coaling hardwood would work fine.
    You could even go back through the cooled-off charcoal and sort it by size, and screen out the fines and ash.
    yooperdave likes this.
