Oh Fourty Fo'
Discussion in 'Chainsaws and Power Equipment' started by cnice_37, Jul 31, 2015.
  1. cnice_37
    cnice_37
    Time to see what all this fuss is about...
    reelcrzy, Nixon, Moparmyway and 15 others like this.
  2. cnice_37
    cnice_37
    S/N is 128...... so I reckon it is the 10mm but I will do a quick teardown and inspection to verify all is good.
    Pshhhhh Creamsicles are all the same flavor, no?
  3. Chvymn99
    :yes:... That one looks pretty darn good too... I hope it turns out good on the inside for you, cause they are known to create a :D on the o' face...:dex:
    It looks like SN# 129583701 and below is 10mm... So you should be good. Plus metal tag and red choke switch are good indicators too....
  4. cnice_37
    cnice_37
    Slanted fins... now I have to man up to the summer heat and find some wood to cut.
    clemsonfor, HoneyFuzz and Chvymn99 like this.
  5. foragefarmer
    foragefarmer
    Central, Virginia
    It should outperform the 038, but that 372xp Randy worked on is going to stomp it. That being said my 10 mm is my go to 70cc class saw. But it isn't a minty saw like yours.
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Sweeet saw !!!
    Chvymn99 and cnice_37 like this.
  7. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Just put in a plug insert in my buddy's 044... needed a piston too. You're going to like that saw-
    clemsonfor, cnice_37 and Chvymn99 like this.
  8. cnice_37
    cnice_37
    Anyone know if this shares same muffler with the 460? My buddy has a spare DP muffler.
    Piston is cherry, aside from a dent in the air filter cover this saw is about as minty as they come in my collection.
    Chvymn99 likes this.
  9. Chvymn99
    No, they aren't the same. But can be used, modifications. I don't remember what mdavlee did, but he made one work for me.
    mdavlee and cnice_37 like this.
  10. mdavlee
    mdavlee
    The 460 muffler is a tiny bit longer. You need to put a couple washers behind it on the lower bolts.
  11. MasterMech
    I think you can use just the muffler cover from the DP on the OEM 044 can to make it a DP. 044 should have a decent sized side outlet already.
  12. clemsonfor
    Yea the cover is the same.
    mdavlee likes this.
