Good news
Discussion in 'The Wood Pile' started by TurboDiesel, Sep 11, 2015.
  1. Eric VW
    Gooder for you, TurboDiesel!:salute:
    Looking real nice. Test pile looks nice......:thumbs:
  2. Erik B
    Erik B
    Western Wisconsin
    While you're making your log catcher you may try using a work mate bench in the mean time.
    TurboDiesel, milleo, JeffGu and 4 others like this.
  3. TurboDiesel
    Its pretty much the same machine except it has the "log cradle" style beam. I'm not sure I like the cradle design as the smaller splits will drop between the cradle tracks. Otherwise it seems to be the same. It might have a shorter cycle time or maybe its a shorter length cylinder, IDK, seemed to go a bit faster. Maybe the pump is a hair different?
    One thing I am sure of , it runs quiet compared to the other one. Better muffler or just not blown out yet.
    Stinny likes this.
  4. TurboDiesel
    The briggs & stratton 675 has no choke lever???
    just a primer bulb. the neighbors had a choke lever but he says it doesn't do anything,
    took a few pulls to get it started when i got it home. Probably flooded from the bouncy ride.
    BrianK and Stinny like this.
  5. JeffGu
    JeffGu
    Osceola, Nebraska
    Sheesh. I have half a dozen of those thing laying around here. Couple of new ones still in the box. Now, I'm going to have to go out in the morning and set one next to the splitter and see if it's the right height. Looks like a great temporary solution! I've been meaning to talk to my welder about making me a log catcher for my Huskee splitter, too.
    milleo, TurboDiesel and BrianK like this.
  6. BrianK
    BrianK
    West central PA
    Better adjust the shocks on the splitter then. Add air.
    Elvisss222 likes this.
  7. Erik B
    Erik B
    Western Wisconsin
    JeffGu By using a work mate bench you don't have to worry about switching to vertical operation then back to horizontal. I like the flexibility it gives me.
    JeffGu likes this.
  8. TurboDiesel
    I like the foot plate extension on yours. that would be handy sometimes in the stringy stuff
  9. Erik B
    Erik B
    Western Wisconsin
    That slips over the foot plate and it does a great job allowing the wedge to cut all the way thru the wood. Works really good with elm and hickory.
    I bolted it togtether when I first made it but finally got it welded up and it works much better.
    VOLKEVIN and TurboDiesel like this.
  10. TurboDiesel
    You just leave it on all the time?
    Really no reason to take it off. Maybe to go vertical...
  11. Erik B
    Erik B
    Western Wisconsin
    I do leave it on most of the time. One has to clean up under it every once in a while. Dirt and little splitter trash gets stuck under it and will make it rise.
    TurboDiesel likes this.
  12. TurboDiesel
    The cradle style beam has drain holes at the ends. The one I was using was like yours, seemed to be harder to clean as it really packed in the corners tight
  13. Erik B
    Erik B
    Western Wisconsin
    I do not have any drain holes in mine,and you are right about those little pieces getting jammed in tight. Scrench works good for prying the stuff out.
  14. 1964 262 6
    1964 262 6
    williamsburg, ohio
    so, if it is gonna be hard to start, i'll give you what you have in it.......lol
  15. TurboDiesel
    Update on this thread. It's been almost three years and I'm solidly on the four year plan. And I've barely scratched the surface here. There are so many tops here that there is just no way to get it all. Not only that, but the BTU gods are still providing and I can't even keep up.:faint:
    Wow! What a wild ride!
    walt, huskihl, Stephiedoll and 14 others like this.
  16. Eric VW
    Hmmmm..... sounds like you need to host a little GTG there, Timbo.....
    :whistle:
    :yes:
    walt, huskihl, TBONE and 10 others like this.
  17. Marvin
    Marvin
    Huntingdon, Pa
    Agreed!
  18. TurboDiesel
    I'm good here.:handshake:
    I'd rather save a Saturday for John Lawler's next cut. It would be great if we could help them out.:yes:
    walt, huskihl, Eric VW and 4 others like this.
  19. Backwoods Savage
    You are blessed Tim!
  20. JCMC
    JCMC
    Just outside of Shushan, NY
    Sounds to me like more of a "YOU SUCK" :DReally gooder for you all that :woodsign: just keep on :saw:
    walt, TurboDiesel, Chaz and 2 others like this.
