Earth Stove
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by StihlHead, Oct 4, 2013.
  1. Richard Stamile
    Richard Stamile
    Oceanside NY.
    OK this answers many things ,on my stove I made the glass door that you see in the photo out of heavy gauge steel rectangle tubing mitered and tig welded and use a 1inch rope gasket
    making sure the the gasket lined up really good and a good seal , the door opening is not very large but being that way allowed to fit the burn tubes and ducked to external air , on the
    7 inch stove pipe there is no stove pipe its designed to use the clay chimney this do to it being an insert rather than a free standing stove where your round 7 inch fitting is there is a rectangle
    damper that lines up with the clay chimney seams to work good i guess i could retro fit it they even sell on ebay a stainless fab part that transitions from rectangle to 6 or 8 inch round pipe
    i guess i could do all this with the flex tube and insulation and all but i wounder if it would make much difference its working fine now and its easy for me to sweep the chimney and has a good draft
    Rich.
  2. wildwest
    Wyoming high plains
    We are replacing an old Blaze King insert w cat next summer. Its free to you if you can economically pick it up in SE wyoming. Not a giant firebox but bigger than newer ones I've seen. KEI-1300.
    If you are near the Rocky Mountains, look at Schrader stoves too, think I heard they were made around here and GIANT firebox.
    DexterDay likes this.
  3. Richcode
    Richcode
    Oceanside NY.
    I just reset my to screen name Richcode and had to start a new account The Irish setter is Opie perfect for curling up in front of the stove
    metalcuttr, papadave and wildwest like this.
  4. DexterDay
    DexterDay Administrator
    Northeast Oh
    I could have just changed your screen name?
    Either way, welcome back :)
    metalcuttr likes this.
  5. wildwest
    Wyoming high plains
    gorgeous pooch.
  6. Richcode
    Richcode
    Oceanside NY.
    He is my brother's Dog , very smart too they live in PA area
  7. Richcode
    Richcode
    Oceanside NY.
    I didn't know about that thanks i was wondering why i could not edit it
  8. papadave
    My SIL had a 1000 series in the house she bought up here, but she bartered it out. Pretty much gave it away, but it was in poor condition.
    Still had the medallion on the door.
    If I run a cross any pics, I'll post 'em up.
  9. Richcode
    Richcode
    Oceanside NY.
    here is a photo of the Stove i think it was maybe 1978 in very good condition no cracked bricks or warped metal
  10. Richcode
    Richcode
    Oceanside NY.
  11. blue factory family farm
    ny
    Hi folks - sorry to take thread in a different direction, but I have a question about these stoves. I just picked up a used Earth Stove Model 100 manufactured in 1978. I'm restoring it now and want to know if the door gasket might be asbestos. The guy I bought it from believes it might be the original gasket, although he is not the original owner. The gasket does not look like a rope gasket. It looks like regular insulation was stuffed in the groove of the door, although it is white. I have been trying to find an image on the web of what the original gaskets looked like in order to compare and find out, but no luck. So my question is did the earth stove use asbestos gaskets or had they phased them out? How do you think I should remove it? (Wet it, etc.) Same question for the insulation over the regulated air intake on the back.
  12. papadave
    Hey bfff, welcome to the forum.
    This may not be considered PC, but I'd maybe (maybe) wet it down, pull it out and put it straight into a trash bag.
    Done.
    Measure the channel for a new gasket, buy it, put it in, and call it gooder.
    There would be such a small amount of asbestos in that, I wouldn't worry. You could wear a dust mask and use a shop vac to clean up the air nearby as you're removing it.
    metalcuttr and wildwest like this.
  13. fox9988
    fox9988
    NW Arkansas 72717
    ^That's probably what I would do.^
  14. blue factory family farm
    ny
    Thanks -I am posting a pic of the gasket so you can see. It does not look like rope gasket at all. It is pretty deriorated. 20141012_174718.jpg 20141012_174718.jpg
  15. Richcode
    Richcode
    Oceanside NY.
    Hey BFFF its not asbestos at all its a kaolin wool if you feel to change it as i did cause i still use the old door with the tile on it
    order the 1 inch round rope its around a little over 6 ft. if i remember , save the wool till you install the gasket you may need some to back up under the rope gasket
    if there is an area where in may not be a good seal this , kao-wool is the same as the insulation in your attic just takes higher temperature
  16. blue factory family farm
    ny
    Thanks richcode - good to know! I would assume then that its the same on the regulated damper intake on the back? I would have taken it out regardless, using the correct procedure. Will probably treat it that way anyway. This stove is a bear! Really looking forward to firing it up'
  17. Richcode
    Richcode
    Oceanside NY.
    Yes BFFF wear a mask and long shirt gloves its can't hurt any sort of particles keep from breathing , good lock on firing it up
  18. Laura
    Laura
    Upper Michigan
    We have this same stove & have tons of questions about dampening & heat regulation please help! This is our stove:
    metalcuttr, Camber, DexterDay and 2 others like this.
  19. Richcode
    Richcode
    Oceanside NY.
    Hi i hope your just showing me a pic of the stove with the pipe on it and don't plan to use your stove as it is in the photo ,
    my Stove is a fireplace insert Earth Stove Colony Hearth , most of the dimensions are the same fire box, door and such but
    before you get started every stove will run differently do to many factors , wood type chimney/stove pipe above the roof line
    i would start by reading as much as you can on the forums right here starting with a fireproof brick pad and back splash and setting
    the stove the proper distance ,
    Rich.
  20. fox9988
    fox9988
    NW Arkansas 72717
    Welcome to FHC.
    What specifically would you like to know?
    Pre-EPA stoves are very simple. Feed it DRY wood, don't over-fire it and keep the flue warm enough to avoid creosote condensation. Keep the flue clean.
    Wood needs to be cut/split/stacked (CSS) for at least one year typically, depending on species. Some species like oak takes up to three years depending on location and conditions.
    Stove temperatures are monitored with thermometers or infrared thermometers.
    The flue needs to be swept occasionally. New burners should probably inspect/sweep once a month until they get an idea of how clean they are burning and then adjust accordingly.
