Dyno tested......... Mastermind ported 660 vs Stock 660 vs Dual port 660
Discussion in 'Chainsaws and Power Equipment' started by Dynomite, Sep 1, 2014.
  1. Dynomite
    Dynomite
    Pennsylvania
    Amazing just plain amazing!!!!!! Thanks Ronnie for sending this saw to test! [​IMG]
  2. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Randy's saw is making more HP @ 12K than the other two did at peak @ 9K! Thats some pretty hot chit!
  3. mdavlee
    mdavlee
    Nice gains and curve. Thanks for testing all this stuff.
    Kg461, Dynomite, Chvymn99 and 2 others like this.
  4. SquareFile
    SquareFile
    somewhere
    Man a stock 660 is a turd, but put a $20 DP cover on it wakes it up!:saw:
    Then Randy takes it to a whole new level:dex:
    Thanks Chad, Ron, and Randy that's just awesome:dancer:
    cgraham1, GRIZ, splitoak and 4 others like this.
  5. DexterDay
    DexterDay Administrator
    Northeast Oh
    Wow... So Hawt!! :dex:
    A min of 2 HP, with about 3 HP being an average. Good job Randy.. :thumbs:
    Ronnie, Thanks for letting Chad use your saw. :)
    Chad, Thanks for taking the time out of your busy day. :)
    cgraham1, Chvymn99 and SquareFile like this.
  6. Dynomite
    Dynomite
    Pennsylvania
    The 660 stands as King in ported version.
  7. mdavlee
    mdavlee
    There around 10.5k rpms they're within .5 hp and that's where a lot of them will cut without a lot of pressure. That's probably why most people with ported ones don't see the big difference in cut speed.
  8. DexterDay
    Northeast Oh
    At 10,500 they are only a 1/2 HP apart! That's still a stout 461! Seeing how it's gonna live right around there in the real world! Awesome! Thanks again! !
    Kg461, mdavlee and Chvymn99 like this.
  9. DexterDay
    Northeast Oh
    Mike beat me by mere seconds! Great minds think alike! :)
  10. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Good point Mike, also of note is that @9.5K-10.5K the ported 660 is making 1HP more. That being said, folks could actually run at a lower RPM, get more and save stress on the saw.
    DexterDay likes this.
  11. Mastermind
    Mastermind
    Tennessee
    The ported 660 needs to run an 8 pin......that would help take advantage of the lower HP point.
  12. Chvymn99
    Wow... Impressive graph... Especially the break down on stock to muffler job to port job. :yes:
    GRIZ and DexterDay like this.
  13. Ron660
    Ron660
    NW Louisiana
    Here's the percent increases of the ported 660 over the stock 660:
    RPM's %>
    8500 = 35.4
    9000 = 37.5
    10000 = 59.7
    11000 = 73.7
    12000 = 180
  14. Ron660
    Ron660
    NW Louisiana
    Randy, I have an 8-pin and I'll definitely switch it from the stock 7-pin.
    GRIZ likes this.
  15. SquareFile
    SquareFile
    somewhere
    :bug:
  16. Ron660
    Ron660
    NW Louisiana
    Here's the percent increases of the ported 660 over the ported 461:
    RPMS's %>
    8000 = 19.1%
    9000 = 15.8%
    10000 = 13.7%
    11000 = 16.5%
    11500 = 19.3%
    12000 = 77.7%
  17. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    An 8 pin would surely keep chain speed up at a lower RPM about 12% different ratio to final drive with the 8 pin. Number wise 9.5k is 90.4% of 10.5K RPMs well within the range of the 8 pin to deliver the same chain speed at 9500.
    Dynomite, mdavlee, DexterDay and 2 others like this.
  18. MasterMech
    This is where dynos do not tell the whole story. If we step up the sprocket size to lower engine RPMs and maintain the same chain speed, what have we gained other than weight? That graph looks to me to be a saw that needs to run a bigger bar in bigger wood than the 461.
    I love how flat that ported power curve is, betcha you can lean on that saw so hard it needs a seat. ;):dancer:
    And what was Stihl advertising the 660 at stock? 7.0 hp? :rofl: :lol: Not even close with the DP, let alone stock.
    @KilliansRedLeo Randy's saw looks to be making more power than the stocker at clutch stall rpm! :D
    GRIZ, SquareFile, Chvymn99 and 2 others like this.
  19. Kg461
    Kg461
    Provencal, La.
    Ya that 660 is a torque monster. Hats off to Randy. Ive always wondered how a ported 461 would do against a ported 660 in wood 25" and under? Anyone know?
    GRIZ likes this.
  20. the GOAT
    the GOAT Banned
    Maine
    It would be interesting to see the saws cutting the same log (before and after ported) and see how the gains in the dyno chart compare to performance in the log.
    cgraham1, GRIZ, clemsonfor and 4 others like this.
