Hello Stoves were manufactured by Danson's Pelpro probably the Cheap Charlie line by the model numbers but they both show the same model numbers?? Maybe there is a difference between CC1 and CCGB1 - anyone know? See pics below Click to enlarge Pic 1 -shows both Danson's Pellet stoves Pic 2 - is tag on back of the larger stove on the left serial 5899 -- 32" tall x 26" wide x24" deep with an Accutron III Pic 3 - is the tag of the smaller stove on the right serial # 7437 -- 28-1/2" tall x 21" wide x 22" deep with an Accutron II
Hello I just found this! Glow Boy -- see pic 2 is the larger size dimensions The larger stove with large fire door window may be the CCGB1 which is the Same size as the Glow Boy Home Heater 120 Or same size as the Pelpro Heater 120 -- see pic 1 is the larger size dimensions CC1 -- CC Franklin 120 or HCF120 Also Edison JR -- see pic 3 is the larger size Also the Pelpro HHPP2bd is the larger stove! http://pdfstream.manualsonline.com/9/91d48964-8eb1-4249-8c21-0cc06154188e.pdf I do not see the smaller stove dimensions anywhere? So What model is the smaller stove?
Hello Many times the dimensions are listed with the specs for each model stove. Also as the model # goes up the stove gets larger in the case of the Pelpro CC1 has the dimensions of my large stove on some of these spec sheets which makes this issue more puzzling? I believe CC1 2 and 3 are generic model #s given to distinguish the size talk about a stove in respect to it's size since most other parts are the same! The smaller stove does have the Glow Boy models along with the generic models I found the dimensions for the large stove but not the small stove? Has anyone found any Glow Boy specs or info for the smaller size stove?
