cast iron fry pan myths
Discussion in 'The Smokehouse' started by savemoney, Nov 8, 2014.
  1. lukem
    I have a big Lodge pan...maybe 16". Love that thing.
    1964 262 6, wildwest and WeldrDave like this.
  2. Razo
    Razo
    Pennsylvania
    I have a #10 modern day skillet from Cabelas, a vintage #8 Griswold and a little baby vintage #3 Griswold. Love em, anybody cook with theirs right on top of the woodstove?
  3. WeldrDave
    Yup, all the time Razo! With cast… Just don't get the pan to hot, it "can" warp! Contrary to what you have may heard, exceeding 450* can screw up a pan. :eek:
    1964 262 6 and wildwest like this.
  4. jetjr
    jetjr
    Pa/Md line
    Yes especially when the power goes out. Also use the dutch oven on there at times
    wildwest likes this.
  5. wildwest
    Wyoming high plains
    Is that a glass cooktop? I have my first one ever, can I use cast iron on it?
    basod and WeldrDave like this.
  6. jetjr
    jetjr
    Pa/Md line
    i do it all the time. i try not to slide the pan a lot though. would not want to drop the pan on it either
    basod and wildwest like this.
  7. wildwest
    Wyoming high plains
    I HAD a cast iron cauldron that I salvaged from the barn at the family farm (est 1871) before it was sold and demolished. I cleaned all the hay, dirt, and bird poop off of it and it weighed a ton. My father offered to refinish it at the plant he worked at, at the time many years ago, and I have yet to see it again. I wonder if something went wrong...?... My founder of the farm made his initial income as a blacksmith so I was confident it was quite old and that he forged it.
    mattjm1017 likes this.
  8. wildwest
    Wyoming high plains
    Phew! Our new cooktop has heating elements that connect two burners and dear husband has already used a large cast iron rectangle griddle on them. Yes, the breakfast was awesome, but we spent a pretty penny on the cooktop, glad to know you have had success!
    CNE deer, papadave and basod like this.
  9. wildwest
    Wyoming high plains
    I imagine things are different in your location, but on my previous Freecycle network in Colorado I saw cast iron cook ware often. Check yours out. PS, its .org, dont bother with .com
  10. wildwest
    Wyoming high plains
    I love breakfast dinners. Sincerely, not a joke.
  11. wildwest
    Wyoming high plains
    I found a small Lodge dutch oven a few years ago during black friday on amazon. Last year I found the large one. Both are ceramic coated which are easier for me to clean, but they still work great on the wood stove when the power is out!
  12. WeldrDave
    No, they are actually cast iron burners. I did the pork chops on the grill and set them there when done to cool a bit. I don't know if you can use your cast on glass or not? It'll hold the weight because it's tempered but it may scratch the surface.
    jetjr likes this.
  13. jetjr
    jetjr
    Pa/Md line
    Ok so has anyone ever put theirs in the woodstove to clean off the gunk to get it ready to reseason if needed? I am thinking of doing mine but was not sure if that would be to hot. Not a roaring fire just a bed of coals type deal.
    WeldrDave likes this.
  14. Razo
    Razo
    Pennsylvania
    yea I'm not sure what to think there, Dave mentioned not to exceed 450 degrees or they could warp, I was on a cast iron cookware site once and they said to re-season, crank your oven as hot as it would go, like 500 degrees, they said it could take hotter but most ovens only go to 500 degrees. I mean I would think cast iron could take a lot more heat than 450 degrees but I've only ever had mine up to 500 in the oven. If Dave is speaking from experience then I trust that he did in fact have one warp above 450
    WeldrDave and jetjr like this.
  15. jetjr
    jetjr
    Pa/Md line
    True that's why I figured just a bed of coals.
  16. lukem
    I don't get crust on mine very often but the couple times I have I put a little water in it and boiled it...then steel wooled...dried...and reseasoned.
    jeff_t and jetjr like this.
  17. WeldrDave
    NOOOOOO!!!:eek: "sorry"... You can destroy the pan, thats a old myth. Go to, http://www.castironcollector.com/collecting.php or http://www.panman.com/portrait.html
    Best thing to do is use Heavy duty Oven cleaner like easy off. I have a pan soaking as we speak. It takes a bit but read those links, you'll understand :cool:
  18. WeldrDave
    Also, by setting it in a bed of coals you can get what they call a "hot" spot area on the pan and could possibly make a weak spot for cracking down the line. You always want to "evenly" heat you pan as best you can. Yes, you can read where people have done that, "but" if it's a nice or a collector pan you really don't want to do that. The best thing is take your time and clean it slow. I always use oven cleaner and put it in a cheap tupper ware container from the dollar store and flood it down with the oven cleaner. Wait a day then scrape it lightly with a plastic putty knife, the Pan man has some good advise. And for the record, yes I'm speaking from expericence, I screwed up a real nice pan once by cranking up our stove to 500* to clean it, it cooled to quick and warped "bad", It wasn't worth a crap then.
  19. Razo
    Razo
    Pennsylvania
    That easy-off oven cleaner method works good, I just put mine in a white kitchen garbage bag and soaked it with oven cleaner for a day, worked real good. Good point about cooling too quickly!
    WoodPirate, jeff_t and WeldrDave like this.
  20. jetjr
    jetjr
    Pa/Md line
    Shew thanks Dave never thought about hotspots.
