Your nc30 needs a convection deck
Discussion in 'Modern EPA Stoves and Fireplaces' started by Highbeam, Jan 17, 2015.
  1. papadave
    Yep, that long cut was finished with the sawzall and I think a bi-metal blade.
    Eric VW and HDRock like this.
  2. HDRock
    I use to cut all tube n pipe with a sawzall till, I had a big job and got my metal chop saw :)
    Chvymn99, Eric VW and papadave like this.
  3. papadave
    I got a cut-off saw from my FIL, but I think it's missing something. I'd have to look at it again.
  4. HDRock
    Cool :cool:
    Eric VW likes this.
  5. capetownkg
    capetownkg
    southern, MD
    Glad to see I am not the only one adding a convection deck this summer. After all the great advice and instructions on here I started mine.
    Looks like me and papadave are about at the same spot! I just ordered an ac30 fan brand new for $100 so waiting on that to arrive to finish her up. Cant wait to see the difference this year
    Eric VW, raybonz, HDRock and 2 others like this.
  6. papadave
    It's a convection deck epidemic!
    That's looking good capetownkg . Didn't wanna' go all overkill on the thickness, eh? :rofl: :lol::whistle:
    I'll be working on mine a little today, between other stuff. Are those self tappers into the tube stock? Did you predrill the sheet?
    Mine will need that, then I may countersink also.
    You got a good deal on that blower, and you'll appreciate how well it moves the air.
    :popcorn:
    Eric VW and raybonz like this.
  7. capetownkg
    capetownkg
    southern, MD
    I think its fairly thick, i went with 16 gauge steel. The screws are self tapping i didnt predrill at all. Im not as worried about overall look since mine is slammed back into the fireplace. Just need to get the back section screwed together and wait for the blower. I followed highbeam instructions and its been great so big thanks to him.
    Highbeam, Eric VW, raybonz and 3 others like this.
  8. papadave
    Had a little time today to grind the top piece, and get the 1st couple coats of paint on.
    I'm gonna' need another can of paint.
    capetownkg, raybonz, Chvymn99 and 4 others like this.
  9. HDRock
    Lookin good
    :popcorn:
    raybonz, Chvymn99 and Eric VW like this.
  10. papadave
    I think I'm cursed.
    Anyway, these supposed metal cutting blades are wearing out faster than I do. By a lot, and I wear out pretty fast.
    Two blades didn't even make the semi-circle cut in the back plate. :hair::picard: I'm gonna' go buy 3 more, just to make sure I can get this done. The plan was to do that today by getting it filed down, cleaned, and painted. I found another can of hi-temp paint I forgot I bought. Yay me.:dex:
    So far...convection deck 3, me 1 (I'm not really keeping score, just taking poetic license to make a point).
    I'm losing the battles, but I'll win the war. By gosh, or by golly.
  11. brenndatomu
    What blades are you using exactly?
    Eric VW likes this.
  12. papadave
    Well, I have these wood cutting blades..........:rofl: :lol:
    Bi-metal, metal cutting blades. Only decent ones I can find, unless maybe I order online.
    Not a metal worker here, so I don't have much experience cutting this "soft" HRS.
    Is there an alternative that's gooder?
    Eric VW likes this.
  13. HDRock
    Oh ,you will win the battle it's only a matter of time, and a little more money:)
  14. raybonz
    raybonz Moderator
    Carver, Mass.
    Are you using cutting fluid? This makes a big difference by keeping the blades cool.. Cut slowly and no sparks..
  15. papadave
    No cutting fluid. Will that keep the blades from dulling so quick?
    Again, complete metal newb here.
    Will WD40 or the like work?
    Eric VW likes this.
  16. Locust Post
    WD40 would be better than no oil but some light weight oil would be better. Even some of your wife's canola or vegetable oil would work. Of course you know you will have to get that oil cleaned off well before you paint.
  17. raybonz
    raybonz Moderator
    Carver, Mass.
    I have mentioned this twice for this reason.. I prefer Tap-Free but regular cutting oil will work.. Blade gets hot it will self destruct..
    Eric VW likes this.
  18. brenndatomu
    Like LP said, WD-40 is better than nothing, but I tend to use motor oil if I don't have any actual cutting oil (which works the best)
    I'd recommend bi-metal blades, about 18 TPI, take it slow, don't push the saw too hard, especially on the curves...and plenty of oil
    Eric VW likes this.
  19. papadave
    Yeah, I know Ray......:headbang:
    I don't have any "cutting oil". Might be able to find some tomorrow.
    The blades were bi-metal 21TPI.
    Had some others in a couple different packs that said they were metal blades. Nope, not this metal.
    Eric VW likes this.
  20. Eric VW
    All above have put it out there...lower TPI, cutting oil, and SLOW!
    Pick up a "flap" or sanding disk on the grindah for smooths. Leave the hand file for your toenails when slippah season comes around....:thumbs:
    raybonz and papadave like this.
