Your nc30 needs a convection deck
Discussion in 'Modern EPA Stoves and Fireplaces' started by Highbeam, Jan 17, 2015.
  1. papadave
    Nope, no plans to put my Crocs up there.:rofl: :lol:
    Chvymn99, HDRock and Eric VW like this.
  2. Eric VW
    Or your Chili....
    HDRock and papadave like this.
  3. HDRock
    No typing, voice recognition:D
  4. papadave
    I'll have to adjust for cooking. hmmmm
    Back to the drawing board.
    Eric VW likes this.
  5. HDRock
    I can still cook on mine, front to back hood is 15" then 10" of stove top
    papadave and Eric VW like this.
  6. Eric VW
    Shoot, add some adjustable pillars... Welded studs to underside of deck, coupler to elevator bolt, to stove top.... Done!!!
    raybonz likes this.
  7. papadave
    I could install a winch on the ceiling.
    Overkill?
    raybonz, Chvymn99 and Eric VW like this.
  8. Eric VW
    Scotty style, or just regular overkill?:rofl: :lol:
    Chvymn99, raybonz and papadave like this.
  9. Highbeam
    Highbeam
    I would recommend 1/8" material minimum. You can cut that with a jigsaw. Just use a metal cutting blade.
    Been running the nc30 pretty hard to heat the shop during this pnw cold snap, 23 OAT right now. The deck and big blower make this stove work more like a furnace with a blast of actual hot air. Kinda makes me want a real wood furnace to get the automatic controls and bigger firebox/blower. Forced air gets you way more heat from a wood fire. Lots of hot air makes quick work of heating big spaces.
    raybonz, Eric VW, Chvymn99 and 2 others like this.
  10. papadave
    Good info HB.
    Lowest temp we've seen so far was 18, but the "deck" really makes a difference.
    Once I get a real one made....I'll be good to go.
  11. raybonz
    raybonz Moderator
    Carver, Mass.
    You do mean gooder to go correct?
    papadave, Chvymn99 and Eric VW like this.
  12. Eric VW
    You got 'em gooder on that one, Ray:rofl: :lol::thumbs:
    papadave needs a little correction every now and then:wacky:
    papadave, raybonz and Chvymn99 like this.
  13. papadave
    I sit corrected.
    Can't stand right now......too....much....food.:stirpot:
  14. DaveGunter
    DaveGunter
    Stripping paint is certainly not very high on my list of fun things to do! I was limited to working in my basement so I used the citrus based, no fumes, eco friendly, non cancer causing stuff, it did little more than make the paint slightly soft, I bet the tetra-ethyl-methyl-death cancer causing stuff works a lot better, some quality time with the angle grinder and a wire wheel got it done though. It's a good thing the stove is in the basement or I might have to paint the stove now!
    Put a new gasket in the door yesterday, the silicone is still setting, will fire it off later today. It's warm out so I can ventilate the basement of the new paint curing fumes. Posted this elsewhere too, but the high density gasket from Englander is waaay better than the crap my stove shop sells, here's a pic of them side by side.
    raybonz, HDRock and papadave like this.
  15. papadave
    I found that out by doing a gasket change last year.
    Should have stuck with the stock stuff, 'cause that's what I ended up with after a short while.
    It's still on there, and I expect it will be for a while longer.
  16. HammerheadC4
    HammerheadC4
    Eastford CT
    That's good to know about the gasket material....my stoves only a couple months old, but I will keep that in mind when the time comes.
    I had a heavy metal cabinet with several shelves laying around.....threw it out in the spring.
    However I do have a Bilco door I saved from a job, was going to use it for a rock sled....but I didn't really need the sled, moving the small boulders with my massey GC went pretty easy.
    I have been thinking about using the Bilco door for a convection deck.
  17. DexterDay
    DexterDay Administrator
    Northeast Oh
    I love mine. . I don't know why Englander ever thought of this..
    I have the 30 blower on mine. The AC-16 (hair dryer looking one) works, but the AC 30 puts out probably double the amount and doesn't make the noise the 16 does. I'd highly recommend going to the 30 or a blower you can adapt to fit that is bigger!
  18. yooperdave
    I can see I'll have to make one of those decks.
    My question is, can you still cook, say, chili or stew on top of the convection deck??
    Eric VW likes this.
  19. DexterDay
    Northeast Oh
    It can be removed in just 2 seconds. It's not permanently attached. It just sets on the stovetop
  20. Eric VW
    Brew on the... top?:rofl: :lol:
    Oh,...... STEW...
    Got it.:thumbs:
