Your nc30 needs a convection deck
Discussion in 'Modern EPA Stoves and Fireplaces' started by Highbeam, Jan 17, 2015.
  1. Eric VW
    What is this tubing, and what is its function?
    Maybe raise your table height?
    A little more speed.... Drill press has different pulleys, right?
    A lighter touch at first to knock down those ridges.
    See what happens with a fresh hole, Dave.
  2. papadave
    The 1.5" square tubing that'll hold up the plate.
    I actually adjusted the speed lower, so I can kick it up a little, and raise the table too.
    Eric VW likes this.
  3. Eric VW
    Ooooh, yes, the square tubing.....had trouble imagining some little round tubing being used:rofl: :lol:
    Yeah, let's see what you can do with a little tweaking on that countersinking......:sherlock:
    papadave likes this.
  4. HDRock
    Maybe you're running the countersink too fast.
    Leave the stock loose, bring the bit into the hole and turn the Chuck by hand so the cutter turns the opposite way it normally does to line up in the hole, be sure it does not move and clamp it down tight.
    I guess it depends how many screws you are going to put in but you could use 3/16.
    I would just tap the tubing no need to tap the top plate.
    I have this speed chart printed out and put it in plastic, hanging by my drill press.
  5. papadave
    Just had a bright idea to weld it all together,.......but I don't have a welder.
    Time for some window shopping. :thumbs:
  6. HDRock
    A welding shop would do it in 10 minutes probably 20 bucks, maybe less IDK, you will need to wire wheel the paint off where the welds go
    Eric VW, Chvymn99 and papadave like this.
  7. papadave
    I think the mechanic in town has a welder. Hmmm.
    He might do it for close to nuthin' for me. Maybe I'll go talk to him.
    I still need to attach the little back plate to the main plate with a couple screws, so back to the problem at hand.
    I'll go mess with speeds and stuff.
    Eric VW, Chvymn99 and HDRock like this.
  8. HDRock
    That would save ya a lot of time screwin around with it.
    if you are going to tap for some screws you need the right size drill bit for the tap , it might be a letter or number size bit
  9. papadave
    I was wondering about that.
    Eric VW likes this.
  10. brenndatomu
    http://r.search.yahoo.com/_ylt=A0LE...art.html/RK=0/RS=uRR2a_w2tPdKTESG1pdUozJGgHY- Drill/tap size chart
    What size screw you thinking?
    You should be fine because the screws will not be carrying any real load and don't need to be ultra tight. But if it is a concern then you can just pick a fine tread pitch (national fine NF vs national course NC) Like a size 10, you have a 10-24 (NC) which will have 24 threads per inch (or 3 threads in 1/8"), a 10-32 (NF) will have 32 threads per inch (or 4 threads in 1/8")
    Eric VW likes this.
  11. raybonz
    raybonz Moderator
    Carver, Mass.
    The rule for tapping is you need at least 2 full threads.. The more the merrier.. As for drill sizes for 1/4"-20 you need a #7 or 13/64" drill bit.. Hard to explain tapping but I can tell you that taps are GH3 which is very hard and brittle.. Turn tap about a 1/8-1/4 turn CW then CCW a bit to break and clear the chips.. YES you need cutting oil ;)
  12. papadave
    Thinking 3/16 or 1/4" screw.
    So, a 10-32 would be a 21 drill, if I'm reading correctly. I had no idea drill were sized that way. How does that translate to a normal standard or metric size?
    Here's a pic of one of the tap & die sets I "inherited".
    Eric VW, HDRock and raybonz like this.
  13. papadave
    Oh, and so Eric is even less confused:D, here's a pic of the painted square tubes.
  14. raybonz
    raybonz Moderator
    Carver, Mass.
    The drill should never be smaller than the recommended size.. With no prior experience I would go with the recommended drill.. There are machinists here that can give a better answer I am sure..
    Eric VW likes this.
  15. brenndatomu
    Yes, a 21 or one that measures .159" diameter.
    I would think going with a 1/4 size would make it easier to find those "specialty head" screws you were talking about...but size 10 is not exactly unusual either so either one should be fine...but then again, I may lean to the larger size just because it can take such a gentle touch to thread steel with the smaller size taps...give yourself the best chance of success...
    Eric VW and papadave like this.
  16. HDRock
    Yep, you're reading it right, don't deviate, use the proper drill bit size as per chart.
    If the hole is too small you will probably break your tap, too large and it will be a sloppy fit and strip easily, done that.
  17. papadave
    This wouldn't work either. :D
    Eric VW, raybonz and HDRock like this.
  18. papadave
    Did a little test this morning with a 13/64" drill and 1/4-20 tap.....a little loosie goosie.
    Just went to the local Ace and got a #7 bit and some 1/4-20 1/2" machine screws. Now, off to the shop I go to see if I can get this done.
  19. HDRock
    Yep, see
    #7 bit-- .2010
    13/64 bit-- .2031
    Did ya use a wood block ?
  20. papadave
    Nope, no wood block. Eye've got a pretty gooder eye. The main plate is done, with some cleanup yet to do. I'll be doing the small back plate tomorrow.
    Here's what it looks like sitting on the stove before drilling, etc......
