Your nc30 needs a convection deck
Discussion in 'Modern EPA Stoves and Fireplaces' started by Highbeam, Jan 17, 2015.
  1. raybonz
    raybonz Moderator
    Carver, Mass.
    Let us know if the new blades and cutting oil help.. I am sure you can handle the pie lol..
  2. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I'd like to have a hardware store around here that sells pies and cookies.
    raybonz, papadave, Eric VW and 2 others like this.
  3. brenndatomu
    Our local grocery store has a ACE hardware attached. The hardware doesn't normally let you check grocerys out there...'cept once in while they'll let their good customers slip a lil snack in with their hardware purchase :whistle: :drool: :thumbs:
    papadave and Eric VW like this.
  4. HDRock
    I buy all my special stuff here, lucky it's only 3 miles away.
    MidStates Bolt & Screw
    If you know exactly what you want you can order it on line from there, believe me they have everything. Search their site you will find what you want.
    If for some reason you can't find it online, call them up they will have what you need
    raybonz, Eric VW and papadave like this.
  5. papadave
    Thanks HD. Looks like they have a place in Gaylord, and looking on the map I've probably passed it a hundred times or more.
    If I can't find what Ray suggested locally, they'll probably be getting a visit from me.
    HDRock and Eric VW like this.
  6. papadave
    Boy, so would I.:yes:
    The bakery is only a couple miles from the hardware, but ya' gotta' know where it is. Just a little building next to these folk's house.
    There's also a bulk food store nearby, and a whole bunch of sawmills around there.
    I bet Dennis is somewhat familiar with Mio area.
    fishingpol, HDRock and Eric VW like this.
  7. HDRock
    Cool, never knew that fact, I did know they had locations in Saginaw and Lansing plus here.
    They are cool, they will sell you two bolts or a thousand
  8. Eric VW
    Maybe they'll sell papadave a couple of extra nuts.....
    :whistle:
    For his pet Squirrel of course......:rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
    brenndatomu and HDRock like this.
  9. HDRock
    They have split nuts too:bug::rofl: :lol:
  10. papadave
    Gots me one of those already. :pain::rofl: :lol:
    HDRock, raybonz and Eric VW like this.
  11. fishingpol
    fishingpol
    So are these decks removable if you want to cook on the stove top?
  12. papadave
    There should be room on the front lower portion for cooking, but yes, mine will be removable with a couple screws taken out.
    HDRock, Eric VW and fishingpol like this.
  13. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    im gonna make one for my blaze king,ill post pics when done:)
    HDRock, Chvymn99 and papadave like this.
  14. papadave
    Just came back in from the shop after finishing the semi circle cut. WooHoo! The 17 TPI blade dulled real quick, despite the oil.:headbang:
    I put on the 12 TPI, added more oil a couple times and got 'er dun. There was only about 3" of cut left.
    Now, I think I'll use the sawzall to make the last straight cut of about 7", then on to the clean up and drilling. Didn't take the phone with me, so I'll take some pics later when I go back out.
    I plan to use the cutoffs as practice pieces for the drilling and tapping.
    Thanks to you guys, I've learned quite a bit.
  15. Eric VW
    Does your jig saw have a variable speed dial, or is "squeeze and go?"
    HDRock, raybonz and papadave like this.
  16. papadave
    Variable.
    I have a Crapsman from many moons ago, but I bought a new one....another Sears model:headbang:......and I'm seeing a LOT of plate movement, so the cuts have a little bevel or angle. Not a big deal on something like this, but it was causing some blade binding.
    Piece of doo-doo. Want it?
    I'm still looking for a gooder one.
  17. papadave
    Got the back piece done, with a couple coats of paint on it and put another coat on the main deck piece. IMG_20160814_125939_284.jpg IMG_20160814_133043_652.jpg IMG_20160814_133051_721.jpg
  18. papadave
    Did a test run on the drill/countersink. Maybe I'm running the CS bit too slow, since there's some chatter. Could also be caused by the piece not being held down well enough.
    Thoughts?
    That's also a 1/4" hole, which I think is too big for this application.
  19. brenndatomu
    If you are not familiar with tapping, take it slow, and don't force anything too much. Depending on the quality and the sharpness of the tap, sometimes there can be a thin line between getting the hole threaded, and just snapping the tap off, especially a smaller one like you will be using. Get it started straight with the wood block trick that was mentioned earlier, once its started good you will notice the tap start to turn pretty hard, back it off 1/4 - 1/2 a turn to break the chip off, give 'er a lil squirt of oil and go again. Stop and back up whenever you feel it getting real tight. You can actually feel the tap start to twist just a bit before they actually break (generally anyways) If you don't have a tap holder wrench to operate it with you can use a small vise grips or cresent wrench, just make sure to use a small wrench, it is much easier to break a tap if you are operating it with a lil too much leverage.
    Hopefully you have a starter tap that has more taper on it and is made for starting threads on a new hole like you are doing.
    They also make a bottoming tap that is more flat on the end and is made for finishing the threads in the bottom of a blind hole.
  20. papadave
    All good info, thanks.
    I was thinking of just tapping the 1/8" tubing. Is there even enough material there for that?
    I'll check the tap & die set I have to see what's inside.
    Eric VW likes this.
