Yellow Birch
Discussion in 'The Wood Pile' started by thewoodlands, Mar 19, 2014.
  1. thewoodlands
    thewoodlands
    You can see the top of this Yellow Birch which was damaged by the ice storm, if the weather permits I'll grab this before Sunday.
    Once the snow melts I should be working in this general area for a couple of months if not longer on all the wind/ice damaged trees.
  2. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Looks like some good firewood !! Be careful out there .
  3. Gasifier
    Yup. Slow and steady during the slippery time woods. Some good BTUs for you and the Mrs. in the future.
    HoneyFuzz likes this.
  4. billb3
    I cut one up for firewood two years ago and found it all rotted in the stack this Winter. The bigger pieces that I split were a little better. Noticed Still had a bit of wintergreen smell on one that I tossed in the stove.
    Have much better luck with grey birch and I have a bunch of 'em that bent to the ground in a bad snow storm a year ago. Never bent back up.
  5. Paul bunion
    Paul bunion
    Birch is notorious for rotting almost instantly if it isn't allowed to dry and kept dry. Was that yellow fully protected from any rain/snow from and well off the ground?
    thewoodlands likes this.
  6. Well Seasoned
    Good stuff! Keep some bark for good fire starter
  7. thewoodlands
    thewoodlands
    I never cover any wood until the year we're going to burn it, I'll check the Yellow Birch I cut last year this weekend.
    I will get some tarps so I can cover what Yellow Birch we have.
    Thanks
  8. thewoodlands
    thewoodlands
    I hope ours is ok, I'll find out soon.
  9. thewoodlands
    thewoodlands
    HoneyFuzz, yes it has some good BTU's. That area gets full sun so with all the melting/rain we've had the snow should be down about 4-5 inches from what's in the picture.
    Gasifier, I always pack down my escape routes before cutting in the snow, the tree has a natural forward lean so things should be fine.
  10. My IS heats my home
    My IS heats my home
    Albany, NH
    No shortage of work to do in Zaps backyard :)
  11. billb3
    All my wood has to be well off the ground because termites .
    Top covered but driving rain would get at it.
    Yellow must be as bad as white for rotting, I don't even bother cutting white any more.
    I only had the one tree.
  12. thewoodlands
    thewoodlands
    We had a nice winter for snowmobiling (short but nice) but I'm ready for some work in the woods.
    It's time to build that wood inventory back up.
  13. Gasifier
    Yup. I hear that!
  14. Backwoods Savage
    Nothing to worry about with driving rain. Unless the wood is punky, it will not soak it up. Wood is not a sponge.
    raybonz likes this.
  15. billb3
    Every raft we built as kids had to be pulled onto shore as far as possible when we were done for the day because if you didn't within a week or two we'd have to raft barefoot.
    Every wooden hull we had had to stay in the water or the chink would fall out.
  16. Backwoods Savage
    And with that Bill, we should know better than to make our wood piles in the lakes!
  17. billb3
    You paint your house trim to protect it from the humidity swelling and contracting due to wood being hygroscopic ( as are many textiles ) resultantly damaging the wood.
  18. Backwoods Savage
    Yes we do Bill and that is also one reason we won't burn it in the stove.
  19. raybonz
    raybonz Moderator
    Carver, Mass.
    Splitting the birch should reduce the potential for rotting.. Tends to rot when left as a round for some reason..
  20. thewoodlands
    thewoodlands
    I did check some yellow birch splits that are stacked on the north side of the house, they looked fine.
    raybonz likes this.
