Xtra Hard Teeth?
Discussion in 'Chainsaws and Power Equipment' started by buZZsaw BRAD, Feb 28, 2021.
  1. huskihl
    huskihl
    Yes to both. But the cutters are sharpened before the chain is put together. Some are sharpened with a fresh wheel, and at some time that wheel needs redressed or replaced. The cutters at the end of the cycle are probably burned a little bit. So after sharpening, they probably drop into a container where they get mixed together
  2. buZZsaw BRAD
    I went to use the 25" bar and chain and didnt realize i hadnt sharpened it. Teeth were HARD and file seemed to glide right over them. Tried with a new file and same result. Tried another chain (not 25") and no problem. Any suggestions? Should i get a diamond or carbide file? Strictly sharpen it with the Dremel? PITA! :mad:
  3. Chud
    Chud
    NC
    What brand files are you using? There is a big difference between Pferd and China files
    buZZsaw BRAD likes this.
  4. The Wood Wolverine
    I’d use the dremel or take it somewhere for someone to grind. You’ll pretty much kill your files.
  5. huskihl
    huskihl
    Usually one sharpening with something a little bit harder will take care of it. A Dremel will work fine. And then you should be able to go back to regular filing
  6. buZZsaw BRAD
    Thanks Kevin, :handshake: i'll give a try. Gotta got some 7/32 bits.
    huskihl likes this.
