Works for me
Discussion in 'Chainsaws and Power Equipment' started by Eric Wanderweg, Jun 10, 2020.
  1. MasterMech
    Tossing another sleeve in between the bushings (have to keep it a snug fit though) will add some stiffness for near-zero effort.
  2. Eric Wanderweg
    I thought of that last night myself :handshake: I ended up turning that 3/4” shaft down to 0.74” to give myself extra wiggle room in the bushings for the mounting plates, but I can easily bore out a piece of steel tubing to make a sleeve that’s a thousandth or two slip fit on the shaft.
  3. Eric Wanderweg
    I didn’t measure but I’m guessing that we got about 8-9” of snow so far and it’s still coming down. I went outside at 8 o’clock this morning excited to try the plow. Reality hit me hard. Despite having wheel weights, 150 pounds of weight on the back, plus my close to 200 pound fat body sitting on the seat, the tires just spun and spun. I need chains obviously. 4 and a half hours of shoveling and I just got back inside. Better get those chains so we won’t see any more snow :)
  4. Eric Wanderweg
    What was I thinking? It just occurred to me that they’re freaking turf tires on there :picard:Made for chugging along on the grass on gentle summer days without tearing up your lawn, not for any real off-road work. All this work designing and fabricating and everything to get to this point just so I could overlook something so simple :hair: Anyway I have a $60 set of chains on order that’ll be here between January 10th-12th.
  5. buZZsaw BRAD
    So that means no more snow! WOOHOO! I like the way you think Eric! :yes:
  6. Haftacut
    Haftacut
    Rives Junction, MI
    We had about an inch this morning but it’s since melted off. Does it look like yours is gonna be around for a while?
  7. Eric Wanderweg
    Rain and temperatures around 50 on Tuesday, then Wednesday is warm too. By then most of the snow should be gone minus the bigger piles.
  8. chris
    chris
    SE WI
    WE gonna get bitch slapped all the rest of this week around my parts and then the highs will be around 12F thrn subtract the wind chill factor :shiver:
    Screwloose, Chud and buZZsaw BRAD like this.
  9. RCBS
    RCBS
    Over here
    Not for some years, but there was a time when I did a whole lot with a 3 speed cub cadet and a trailer just like that one. Later, I found the limits of such a trailer when I killed one hauling a 55 gallon barrel of water in it. Was trying to get water to a remote food plot. Rigged the barrel up with a valve and water bar about 5' wide. Would back the trailer down the sandbar into the river to fill it (cut a large hole in top of barrel). It lasted about 8 trips up the hill before the wheel bearings went on strike. The plot did grow well. lol
    Screwloose, MAF143 and Eric Wanderweg like this.
  10. Eric Wanderweg
    Ready to rock and roll now!
  11. buZZsaw BRAD
    Do those get traction in mud too? :D
  12. Eric Wanderweg
    LOL maybe… But I do plan on buying some knobby tires for it next month anyway. Kind of like this:
    I’ve *heard* they won’t tear up the grass as long as I’m not being stupid…
  13. Eric Wanderweg
    I should make some larger heavier wheel weights for it too. I think I have some extra steel that’s been sitting around long enough.
  14. MasterMech
    Chains work great in grass too - same disclaimer. But they are pretty insufferable on hard surfaces. Bumpy ride!
  15. Eric Wanderweg
    Just got some new shoes for the old Cub. More aggressive than the turf tires but not too crazy. They’re supposed to be “all season” tires.
    Chud, Screwloose, eatonpcat and 7 others like this.
  16. brenndatomu
    I put a set of those on the ole Z turn mower a couple years ago...big difference! Haven't been stuck since...they'll dig a big hole in a hurry once you start spinning though...no experience with them on snow/ice, but I'm sure they'll do a lot better in snow, ice will probably still require chains...
  17. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Where did you find those at? Should get some for the Hydro 185 with blower on it.
    Screwloose and eatonpcat like this.
  18. Eric Wanderweg
  19. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Thanks Eric, I will have to look into them.
  20. Eric Wanderweg
    I got the Ag tires mounted a couple months ago, but we haven’t gotten much snow (Murphy’s Law) Still I put the plow on and chains on the tires. I took the factory wheel weights off and drilled/tapped a couple 1/2-13 holes, then made a mounting bracket for these weights. I’ll have to turn up a couple discs with a hole in the center for a 1/2 bolt, for end caps to keep the weights on. This is the gist of things anyway. Two 45’s and 2 25’s plus the mounting brackets should add over 160 pounds to the back end, which is better than nothing. It looks a little wonky but should work.
