Work thread
Discussion in 'Everything Else (off topic)' started by trapper brad, Jun 5, 2022.
  1. Buttermilk
    Buttermilk
    Central AR
    This dozer quit. Worked quite a while and finally found a wire rubbed into going to the ecm. 20230822_143021.jpg
  2. Buttermilk
    Buttermilk
    Central AR
  3. Buttermilk
    Buttermilk
    Central AR
    Went in at 5 this morning and got off at 4. Then came and done this. Dad rolled the round hay and I square baled. 81 rolls and 340 square. I went ahead and stacked two rows together because it will be just him and me tomorrow. Can't get anyone to work anymore
    spotted owl, FarmerJ, Skier76 and 8 others like this.
  4. The Wood Wolverine
    My son welded these trusses at Gaumer Industries for a couple years.
  5. brenndatomu
    Those look spiffy!
    Welding on my log splitter build here lately I was having trouble seeing the weld puddle real well...welds not looking the best, worse than normal for sure, thought something was going on with my lens...tried it wearing some reading glasses, yup, that helped! Guess its cheater lens time. :picard:
    FarmerJ, Chvymn99, Screwloose and 5 others like this.
  6. The Wood Wolverine
    I should have added those are for big dump truck rear suspensions, like seen on post #137.
    And I'm fully dependent now on readers. I think the more you use them, the quicker you become reliant. Sucks. I'm at a point if I try to look further distances through them, I get 1/2 dizzy.
  7. Buttermilk
    Buttermilk
    Central AR
    No pics today. I'm home sick as a dog. Got the flu, covids, or hebejebes or something. Not feeling good at all.
  8. Woodwidow
    Sorry to hear that. No fun being sick.
  9. Screwloose
    Screwloose
    I had to get prescription glasses made just for welding. Trying to position your head in a helmet with trifocals is a joke.
    Adding a helmet bib really helps block out the reflected light.
  10. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Shake it off dood....
  11. Buttermilk
    Buttermilk
    Central AR
    A day at your compound eating some of the good things you cook would probably have me back on my feet quickly
  12. T.Jeff Veal
    That has headache written all over it. :tip::tip:off to you, brother.
  13. FarmerJ
    FarmerJ
    Minnesota
    My load taking me to Wichita KS
    Brand new Cat D6. Yes, I had to drive it on myself. No spotter even.
    Empty I’m 38,000 lbs.
  14. Buttermilk
    Buttermilk
    Central AR
    Another dump cylinder and then sprocket segments on the 450 20230829_124136.jpg 20230829_124119.jpg
  15. Woodwidow
    It always amazes me to think you can take all that stuff apart and put it back together as it is so big. Hoists and lifts must be your friend.
  16. Buttermilk
    Buttermilk
    Central AR
    Yes sir they are.
    brenndatomu and T.Jeff Veal like this.
  17. Buttermilk
    Buttermilk
    Central AR
  18. T.Jeff Veal
    That's a job. Our tractor counterweight has 2 D8 rollers on it. They are HEAVY. 0608221846.jpg
  19. Buttermilk
    Buttermilk
    Central AR
    Yes sir. It's not bad after a couple 100 of them. Lots of good weights
  20. FarmerJ
    FarmerJ
    Minnesota
