Work Done In 2020
Discussion in 'The Wood Pile' started by thewoodlands, Jun 13, 2020.
  1. yooperdave
    Looks good, as usual. :handshake:
    mat60, thewoodlands and T.Jeff Veal like this.
  2. thewoodlands
    thewoodlands
    I took it down much lower, I just didn't take a picture. I have a some stumps that I won't dig up this year that will get lowered closer to the ground but I'll use the 660 which wasn't in the Rhino.
  3. thewoodlands
    thewoodlands
    Since it was a nice day today, I did the fall cleaning of the gutters. I did get back by the Brook and did a small job the wife wanted done before the gutters.
  4. thewoodlands
    thewoodlands
    I had some smaller rounds that I stacked first and then split some other rounds I had left from the spring ash felling that finished up this stack.
    mat60, T.Jeff Veal, EODMSgt and 3 others like this.
  5. Loon
    Loon
    North of the border
    You are a busy guy woods! :cheers:
  6. Czed
    Czed
    Wv
    I had a scetchy job for my niece
    This poplar which they said was oak.
    Was hard leaning towards a power line.
    We wedged a 450 against the lean
    The winch is broke
    The dozer operator said this makes your heart go pitter patter IMG_20201105_113750.jpg
  7. yooperdave
    Glad it went well. :handshake:
    Czed, mat60, T.Jeff Veal and 2 others like this.
  8. Loon
    Loon
    North of the border
    Um! Pretty sure this is cheating Czed! :coldone:
  9. T.Jeff Veal
    X2, I've used the 'Bota numerous times to nudge them the right way
    Maina, yooperdave, Loon and 1 other person like this.
  10. sirbuildalot
    sirbuildalot
    Mass
    Not cheating!!! Just working smarter!!!
  11. buZZsaw BRAD
    I wouldve needed some depends on that one! Great job!
    Maina, Czed, T.Jeff Veal and 2 others like this.
  12. Loon
    Loon
    North of the border
    Never thought of that!
    Maina, T.Jeff Veal and yooperdave like this.
  13. thewoodlands
    thewoodlands
    I'm still doing my dead pine cleanup of this area, in picture 1156 you can see the base was rotten and in picture1158 is the dead pine I felled/split, four loads went over to the outside fireplace
    The last rounds I split were from the downed pine in picture 1155, another two plus loads were split and brought over to the outside fireplace.
  14. Czed
    Czed
    Wv
    Cutting standing dead for my nephew
    He's no saw man.
    I give it to his neighbor with copd
    He can't cut much anymore.
    High winds were to my back and helped
    Spin this into a pocket I had for it.
  15. T.Jeff Veal
    Making your woods look very nice
    Loon, buZZsaw BRAD and Maina like this.
  16. T.Jeff Veal
    Good job. Glad you could help his neighbor. FHC at it's best
  17. thewoodlands
    thewoodlands
    Thanks T.Jeff Veal , I hadn't planned on doing this much on clearing dead pine this year but I'm glad I did. I did get rid of about seven stumps this fall from some of the stump pulling I did in 2018 which opened up the first trail into the area I'm working.
    The worst part of opening up this area.....more dead pine that I'll need to take care of.
    Maina, Loon and yooperdave like this.
  18. thewoodlands
    thewoodlands
    This morning when I went to start the Rhino it didn't want to start (it was only 17.2, not that cold) so the first thing I did was check the positive and negative connections. Both posts had no buildup but the positive was loose so I tighten that up and put the trickle charger on it for an hour.
    While it was on the trickle charger, I made my way to the fireplace and started a nice fire with the dead pine. After an hour on the trickle charger I used the Rhino most of the of the day hauling more dead pine over to burn, the battery seems fine but we'll see.
    I used the RTV the last three hours of the day hauling more dead pine over to the reducer, once the RTV warms up, that heater will make it real toasty inside the cab but I still missed the cold breeze you get out in the open with the Rhino.
    Maina, Loon, yooperdave and 1 other person like this.
  19. Erik B
    Erik B
    Western Wisconsin
    My garden tractor refused to start yesterday. It clicked a few time like it wanted to start, but then it went dead. I bought a new battery today thinking that would fix the problem. It didn't. I checked the seat interlock and that was good, I jumped the terminals and it still wouldn't start. I don't know where the other interlocks are so it will be taken to the dealer to get it fixed. :headbang::headbang::headbang:
    Maina, Loon, T.Jeff Veal and 2 others like this.
  20. B.Brown
    B.Brown
    USA
