Woodstock Ideal Steel install
Discussion in 'Modern EPA Stoves and Fireplaces' started by fortydegnorth, Dec 26, 2016.
  1. T-Stew
    T-Stew
    Great looking install there and welcome to the club! But it doesn't look like that hearth has enough pad in front of the stove door?
    HDRock likes this.
  2. HDRock
    You're right but all he has to do is cut the carpet back because it's in the basement
  3. fortydegnorth
    fortydegnorth
    Kettering Ohio
    Tile is being laid now that extends 19" on the floor. Pictures are not of the completed project, just progress so far. Drywall, trim, tile...lot of pieces to finish.
    milleo, T-Stew, HDRock and 1 other person like this.
  4. Rearscreen
    Rearscreen
    Not to belabor this point, but if it's at the end of the circuit and you buried it it's somewhat fine since there is no draw downstream, however, it would be best to find the junction upstream of that and disconnect it. Explanation: burying a box is risky. If there is any chance of a carbon build up thus resistance it would be at a junction. Case in point: a month ago the lights did not work in my basement. All low draw LED's. Being someone who plays an electrician on TV and am comfortable with Tesla, I opened the junction where the switch was. All connections were twisted and soldiered by a Vermont Yankee electrician! The neutral twist was corroded apparently as when I touched/moved it the lights went on. IF this were buried, no way would I find the fault.
    TurboDiesel, burndatwood and Eric VW like this.
  5. fortydegnorth
    fortydegnorth
    Kettering Ohio
    The box is capped and attached to a stud. The only reason I left it in the wall is so I can add the outlet back. The plan is to cut a section of drywall out near the corner and add the outlet back. I just haven't had time, and didn't want to cut the drywall out yet. This was a temporary fix to get the outlet and wire away from the stove wall. All a work in progress. My brother-in-law is a journeyman electrician so we are in good hands.
    milleo, TurboDiesel and raybonz like this.
  6. raybonz
    raybonz Moderator
    Carver, Mass.
    Wrong it is illegal to bury a box! It must be accessible! This is the law (NEC) not my opinion.. BTW soldering is an excellent method of making connections if done correctly..
    TurboDiesel likes this.
  7. raybonz
    raybonz Moderator
    Carver, Mass.
    Welcome to the forum fortydegnorth ! That is a great looking installation! Good looking stove as well.. WS is an excellent company with knowledgeable people!
    milleo and TurboDiesel like this.
  8. Kimberly
    Kimberly
    The Kangaroo State
    Did you find any rebar?
  9. fortydegnorth
    fortydegnorth
    Kettering Ohio
