Woodstock Fireview Rebuild
Discussion in 'Modern EPA Stoves and Fireplaces' started by Todd, Jan 5, 2025.
  1. brenndatomu
    Fell through (into?!) someone's crack?
    I'd inquire about it again, as a reminder if nothing else.
    Horkn, wildwest, Eckie and 1 other person like this.
  2. Eckie
    Eckie
    Could call them. I've always had excellent communication over the phone.
    Horkn, wildwest, Todd and 1 other person like this.
  3. Todd
    Todd
    NW WIS
    All my parts are being shipped out today including rebuild instructions and furnace cement. $1037.00 total
    Horkn, wildwest and brenndatomu like this.
  4. wildwest
    I wonder if you could moisturize the soapstone you're taking off and use for something else?
    Horkn, Todd and brenndatomu like this.
  5. Todd
    Todd
    NW WIS
    Not sure what you mean by moisturizing? I’ll probably make some boot warmers, trivets and anything else I can think of.
    brenndatomu, Horkn and wildwest like this.
  6. wildwest
    Wipe some mineral oil on it for the flaking and prevent further flaking? I don't have soapstone, just a thought. Your ideas sound cool!
    brenndatomu, Horkn and Todd like this.
  7. Ohio
    Not Ohio
    Looks good. I’m bookmarking this thread for when I need to rebuild my stove in 20 or so years.
    metalcuttr, brenndatomu and Todd like this.
  8. Todd
    Todd
    NW WIS
    Received most of my parts today and they really package them well, no broken stones. I’m missing a few stones though. The outside corners and some inside corners. I don’t know what happened there but I’m sure they will fix it. Also no instructions so I’m kind a dead on the water until I hear back From them.
  9. Todd
    Todd
    NW WIS
    Finally have all the parts! It’s a pain trying to keep the corners from falling in as I rebuild this thing, had to get creative. Have all the stones together just need to cement them together the install the guts.
    JD Guy, ginger1313, moresnow and 3 others like this.
  10. Todd
    Todd
    NW WIS
    Cemented everything today. Lots of seams to fill then I installed the four corner tie rods and legs. Had a problem seating the top frame in one corner and then I heard a scary pop and she went into place.
    I’ll let the cement dry tonight then start on the guts tomorrow. Install maybe next week.
    Chaz and brenndatomu like this.
  11. Todd
    Todd
    NW WIS
    Installed the guts today, went together pretty well. Only had a couple issues with a couple spacers that help line up the combustor pan and the bypass was a pain to reinstall and adjust it properly.
    Chaz, billb3, Eckie and 1 other person like this.
  12. Todd
    Todd
    NW WIS
    I have to let it sit for a couple days to cure the cement then I’ll install maybe Wednesday.
    I think I’ll do three small break in fires without the cat in there. Not sure all the paint fumes passing through is such a good thing?
    Chaz, moresnow, Eckie and 2 others like this.
  13. Todd
    Todd
    NW WIS
    Installed and ready to go! Woodstock says to wait 48 hours before break in to cure the cement. I cemented all the stone and firebox last Saturday but did the flue collar and combustor pan gasket IMG_1954.jpeg yesterday. Maybe a small kindling fire tonight? What you think Backwoods Savage ?
    Chaz, MNWood, BCB and 4 others like this.
  14. VTAbstoluteSteel
    VTAbstoluteSteel
    Orange County, VT
    Looking at the location of that CAT I can see why the top of the fireview gets HOT
    My Absolute steel had a hood scoop on top of the CAT that throws the heat at a soapstone piece in the front. I overall like it because it pushes heat forward but I cannot really cook with it when the power goes out.
  15. Todd
    Todd
    NW WIS
    IMG_1955.jpeg IMG_1958.jpeg Small break in kindlings fire. Right before that I noticed a crack in the top lid frame.
    Chaz and Backwoods Savage like this.
  16. Backwoods Savage
    That looks great Todd. I would think a small kindling fire would do no harm.
    Chaz and Todd like this.
  17. Todd
    Todd
    NW WIS
    Small kindling fire last night. Top stone up to 200. Just did another break in fire a little larger and hit 300. I’ll let her cool down and shoot for a 400 degree fire with the cat engaged. It will be interesting to see how this 23 year old cat works. I do have a new steel cat on back order from WS but don’t know when that will show up? Seems Woodstock has been having issues keeping these cats in stock the last couple years, they need to fix that.
    Chaz, billb3 and brenndatomu like this.
  18. Todd
    Todd
    NW WIS
    She’s fully broke in and just loaded her up for an overnight burn. No issues except the cracked top frame. WS say it should be fine and to just smear some cement on it, sand and paint. A new frame runs $120 plus shipping so I’ll just see how this goes the rest of the season. IMG_1962.jpeg IMG_1964.jpeg IMG_1965.jpeg IMG_1972.jpeg
  19. Todd
    Todd
    NW WIS
  20. Todd
    Todd
    NW WIS
    Packed full of oak last night and not many coals left this morning after 10 hours. I kept turning the air down until I was just a smidge above 0. Stove temp 650 internal flue temp 600. I think the flue temp may be a little high but I also had a strong draft with single digits outside. -17 this morning too. Ended up tightening the bypass a bit because it seemed loose. Still learning the stove but I remember being able to snuff out the flames on my previous Fireview but that was a different house different chimney.
