Woodstock Absolute Steel - How to burn slow and low
Discussion in 'Modern EPA Stoves and Fireplaces' started by FeelTheBurn, Dec 17, 2018.
  1. Camber
    Camber
    Montana
    I might have missed it, but is your wood truly dry. If not then you will have lots of char left as the stove burns from being hot on the shutdown to start with. Even splitting small like four inch splits you can run into that. I had a customer that was doing everything right, but he was not burning 20 MC and under. It was all he had though.
    Chaz, mat60 and Maina like this.
  2. Mwalsh9152
    Mwalsh9152
    Pelham NH
    Yes, the stove.was down to about 200-250ish STT this am. I opened the air and cracked the door while keeping the cat engaged to get the large pile of coals to.start throwing heat. It was still 69F on the first floor where the stove is.
    Chaz, Camber and Maina like this.
