Wood you would like to try...
Discussion in 'The Wood Pile' started by Fanatical1, Jan 27, 2018.
  1. Enzed Bill
    Enzed Bill
    New Zealand
    I guess the grass is always greener in the next paddock, but I must admit I envy the choices most of you have.
    Here is NZ there's essentially one softwood - pinus radiata (Monterey pine), usually just called "pine", and there's one affordable hardwood - "gum" aka eucalyptus. Gum covers a lot of different varieties with different characteristics - but people can seldom tell you what sort of gum they have so it's pot luck.
    Apart from those two I've only ever had: some oak (a hatchback load, not even one cube), which was lovely to split when it was green and impossible when I let a few rounds dry; one memorable 3 cubes of "sheoak" (casuarina), which was absolutely marvellous - I've watched out for it ever since but never seen any more come up in my area; and one mystery tree, which the owner couldn't identify (it blew over in a storm). One visitor who inspected my stacks thought it might be black wattle, another guessed mulberry - it's all gone now, so we'll never know, but it did burn long and hot.
    Anything more exotic that pine or gum is usually from someone's garden. There are numerous native hardwood trees but they are generally very expensive and, due to their aromatic qualities, often diverted to either smoking or to native Maori ground ovens, called hangis. Most adult native trees are protected and there's a lot of bureaucracy involved in cutting them down.
    Still, pine (despite the chimney sweep's objections) is good kindling if properly seasoned, and gum is a fine hardwood very resistant to rot and mould in the stacks. So I should count myself lucky to have both.
  2. blacktail
    blacktail
    PNW
    I've never had locust. It would be nice to try some.
    I'd also like to get some wood from a monkey puzzle tree, just so I could say I'm burning monkey.
  3. WeldrDave
    I ate it once... :whistle:
    FatBoy85 and Backwoods Savage like this.
  4. FatBoy85
    FatBoy85
    Washington State
    Western or Eastern?
  5. FatBoy85
    FatBoy85
    Washington State
    If you’re interested in trying some I’ve got a couple logs or splits you could have. I’ve got loads, happy to share.
    blacktail likes this.
  6. blacktail
    blacktail
    PNW
    Thanks for the offer, but it's a long haul down your way.
  7. FatBoy85
    FatBoy85
    Washington State
    Longview?
  8. bear 1998
    bear 1998
    S.C.Pa
    Where did you live in Adams County....I'm familiar with everything you are talkin about.....where do live now?
  9. The Wood Wolverine
    I have a Gettysburg address but live about 10 miles north of town. You close?
  10. bear 1998
    bear 1998
    S.C.Pa
    Very......About 5 miles N.W. of Arendtsville
  11. Steve
    Steve
    Pefferlaw, ON
    A regularly debunked myth around these parts. Burn with confidence Enzed!
  12. The Wood Wolverine
    Cool. I live in Heidlersburg. Mostly get from Fetters Orchards (Tyler is my friends name).
  13. Matt Fine
    Matt Fine
    New York
    We have plenty of good hardwoods to burn for heat so I see no need to lust for anything else. Mostly oak, ash, locust, and maple get fed to the stove plus any excess hickory and cherry. So far I have found all hardwoods that have beer seasoned will burn and produce heat. If I want a longer burn I grab higher density heavy splits, and don’t worry about species. For the most part, dry mass = BTUs.
    Most hickory and apple goes to the smoker, sometimes with oak maple or cherry and the occasional imported mesquite. If I was going to wish for another wood to be available locally, it would be alder to use in the smoker for fish. In the smoker I am after flavor more than BTU’s so species matters.
  14. bear 1998
    bear 1998
    S.C.Pa
    Do you know a Tony Fetters? I have been lookin for orchards that are being pushed over but havin a hard time time findin any. I did service work on appliances n alot of growers walk in coolers for 20 years.....found a new job in 2000 n lost all my connections plus as much as I used to travel I had a good chance to see who was pushin trees over.....do you know of any at the moment??
  15. Enzed Bill
    Enzed Bill
    New Zealand
    I think there's a typo there. You probably meant to write "... all hardwoods that have been beer seasoned ..."
    I must admit I would never have thought of doing that. How long do you soak the splits in beer before stacking?
    Steve, Matt Fine and Erik B like this.
  16. Matt Fine
    Matt Fine
    New York
    18 months in beer followed by 3-4 years open air drying.
    Steve likes this.
  17. Erik B
    Erik B
    Western Wisconsin
    Maybe the alcohol in the beer draws water out of the firewood faster:hair:
  18. Matt Fine
    Matt Fine
    New York
    Exactly! It lowers the surface tension while adding the aromas of malt and hops.
    Erik B and Steve like this.
  19. Steve
    Steve
    Pefferlaw, ON
    Pickled oak?
  20. Enzed Bill
    Enzed Bill
    New Zealand
    It would explain why when alcoholics go into rehab for a long time they are said to be "drying out".
    Obviously an analogy to the New York seasoning method.
