Wood Tallies going into March!
Discussion in 'The Wood Pile' started by WeldrDave, Feb 26, 2019.
  1. mike bayerl
    mike bayerl
    11270484_10203982263825967_4651188404873194077_o.jpg 11312765_10203982264465983_2423996365300278218_o.jpg
    Horkn, Chvymn99, Stlshrk and 13 others like this.
  2. papadave
    So, my memory isn't as bad as I thought.............
    Very nice.
    Rope, Horkn, Chvymn99 and 10 others like this.
  3. coreboy83
    coreboy83
    NW of Twin-Cities
    Kind of impressive, honestly
    Rope, Horkn, Chvymn99 and 6 others like this.
  4. Thor
    Thor
    Genoa City,Wi
    Had to get out the calculator. 1.59 cord. Next week back into the lower teens. Time will tell.
    Rope, Horkn, Chvymn99 and 8 others like this.
  5. papadave
    Yeah, I impress mysel......oh wait, you mean his stove.
    Yep, nice, isn't it?:handshake:
  6. WeldrDave
  7. JustWood
    JustWood Guest
    Hard to tell because I pull wood out of the heaphausen till the snow gets azz deep to a tall Eskimo then pull out of an attached shed. Sheds almost empty . Pretty sure it's less than past years. I've done a fill and 1/2 and I'm usually between 2-3 this time of year.
  8. billb3
    bear 1998, Rope, Horkn and 6 others like this.
  9. gboutdoors
    gboutdoors
    S.E. Massachusetts
    2 cord to date with 1/2 cord left for March. Normal use is 2 1/2 cord but have 7 1/2 stacked so not worried.
    Rope, Horkn, Chvymn99 and 4 others like this.
  10. Spencer
    Spencer
    Indiana
    Probably close to 3 cord. I used 11 skids worth of wood stacked 2 ft high. I just ran out of good seasoned wood. burning some slightly wet sassafras on the coldest evenings just to warm up the family room.
  11. Rowerwet
    Rowerwet
    Seacoast NH/MA
    Closing in on 4 cords up in smoke.
    This winter has been a pathetic failure, with no snow worth mentioning , and a whole bunch of hype that gets me excited , then we get rain.
    Even the polar vortex didn't really happen on the NH seacoast.
    Now that winter is over, the weathermen are cranking up the snow hype again, I fail to be impressed.
    Unless it gets cold and stays that way for more than 3 days, this could be a mild 5 cord winter
    Rope, Horkn, Chvymn99 and 9 others like this.
  12. Maina
    Maina
    Maine
    About 3 1/2 cord so far, including 1/2 cord of pine and another 1/2 of badly spalted birch and beech. I have 1/2 cord of KD and 1/2 cord of uglies and pine with at least 2 months to go, so I brought home a ton of Lewis wood bricks yesterday to mix in. Working great so far! The goal is to not burn oil. We’ve been running the heat pump when it’s below the teens to supplement upstairs also. That added about $50 last month. It’s been colder than average here all winter and it started early. Here’s hoping it ends early too but I’m not holding my breath. Hope for the best, plan for the worst.
  13. amateur cutter
    North of 10 cord heating the whole place. Got probably 12 cord on hand yet. 7-8 pretty dry. Been a very windy cold 2nd 1/2 of the winter here. Shop is the big heat suck during the day with doors up & down & cold vehicles coming in all day long. Really don't care though as temp stays at 70 24/7. No cold restarts, no 48 degree mornings inside etc. Water is always hot & the floors are always warm. Best investment I've made in years, along with siding & more insulation. Wood's easy to come by for me, so let er burn.
  14. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    I would only be guessing as some is piled under a tarp, some is on a hay rack (empty) on a flatbed wagon (just started on this week) and two sheds full (one empty one clear full yet). Until getting on here, never thought of wood as cords, only pickup loads.
  15. MikeInMa
    It looks like I'm coming up on the 3 cord mark. Just about right for us, I'd say.
  16. Stlshrk
    Stlshrk
    Central Virginia
    We are at about 3 1/2 cord in so far this winter. For reference, we're in Central Va, heating with an Orlan Eko 40 Gasification boiler, 2800 square ft via forced air heat exchanger, 750 gal of hot water storage, plus domestic hot water.
    Once I finally insulate my shop, I will open that loop with a unit heater for an additional heat load. We are looking forward to keeping that 40 - 50 f, and could crank it up when working in there.
    Miss September loves the amount of hot water for showers in the winter. I'd jokingly bet her that her "habit" costs us a min of 1/2 a cord per winter. I think she would not care if I removed the tempering valve (anti-scald)...
    :rofl: :lol::banana:
    Rope, Horkn, Chvymn99 and 7 others like this.
  17. M2theB
    M2theB
    Central Massachusetts
    You kick me, I’ll kick you.
    About 4 1/4 into what should be 4.5 for the season.
    Bought the gasket in September and never got around to it and then lit the stove and it’s been on mostly since.
    I bet that mistake will cost me 3/4 cord or better.
    bear 1998, Rope, Horkn and 10 others like this.
  18. yooperdave
    Hello there shipmate! Your assumption is correct, she would not mind at all.
    99 lbs loves heating season for the hot water! No valve here.
    bear 1998, Rope, Horkn and 4 others like this.
  19. Breechlock1
    Breechlock1
    Ha. Yeah I can't believe how much of a difference it made
    bear 1998, Rope, Horkn and 5 others like this.
  20. Jon_E
    Jon_E
    Southwestern Vermont
    Well I solved my problem. Found a Facebook Marketplace ad that had only been posted for 12 minutes, guy selling 3+ cords of dry hardwood. I was the first one to respond, went to look, bought on sight. Turned out to be closer to 4 cords, maybe more, of bone-dry, 4-7 year old mixed hardwood, cut split and stored under cover. Mix of mostly sugar maple, red oak, ash, shagbark hickory and few other species mixed in. Apparently his wife developed a woodsmoke allergy and couldn't burn wood anymore. Went to pick it up today and he said he had over 25 inquiries on it even after posted sold. Oh yeah $550, so a good deal for this area. I gotta go take some MC readings but I bet all of this stuff is under 15% MC.
    bear 1998, Rope, Horkn and 11 others like this.
