Wood Stove Selection!
Discussion in 'Modern EPA Stoves and Fireplaces' started by brokenwing, Dec 22, 2014.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I am gonna chime in here I can understand your confusion on the topic.
    There are multiple ways of heating your home and to be honest from your video a wood stove would work but not as effectively as you would want. As pointed out the back pantry would be colder. Also if it's not considered air tight then it's going to be a pita to heat in the deep cold.
    The two options that look like winners are an Indoor wood furnace which there are some very good ones out there or an outdoor boiler. Outdoor boilers use an incredible amount of wood but that's no issue for you as I understand it.
    The indoor furnace would probably be the better bet for you.
    Indoor furnaces can be EPA stoves with efficient secondary burning. They do use a lot but not anywhere near as much wood as the outdoor boilers do. An indoor furnace would pump heat through vents but unlike a gas furnace it would be consistent heat. Gas heats up a room temp then shuts off wood furnaces can be set to pump consistent heat to each room and are very nice because there isn't a 5 minute furnace blast then a cool down and blast again. It simply pumps even heat.
    The englander indoor furnace is non EPA and therefore not as efficient of a stove to burn. Non EPA is not bad necessarily however I can attest having owned both we get far better heat out of the EPA stove than the non EPA.
    The outdoor boiler would work but you need to run radiant water lines into the house and back to the boiler. They are a good option for you but it does use a lot of fuel meaning a lot of work to get said fuel.
    I hope I haven't confused you further.
    wildwest likes this.
  2. Pallet Pete
    Ovid
  3. mj_deere
    mj_deere
    Western Ia
    Here's my opinion, take what you will out of it. I would look into an inside stand alone wood stove with two blowers. I would make a plentum to run the two discharges off the top of the stove into. To get the heat into the other rooms use round furnace pipe coming from the plentum. It would give it a rustic but modern look with the exposed heat runs. At the end of the runs a person just puts a register cover on to clean the look up.
    LongShot and wildwest like this.
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    I still think the less than open floor plan may make things difficult to circulate and move warm to all areas of the house.
    concretegrazer likes this.
  5. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    I am going to chime in on this one too. I would like to see more insulation in the attic of the home he is building. R13 in the walls in Missouri would probably be ok. But, an R- 38 in the attic is almost standard in new construction nationwide. For heating and cooling purposes. That R-38 is achieved with a 12" fiberglass batt. Pretty cheap at any home center .... Depot, Lowe's or Menard's. Once insulated properly the choice of wood burner is less complicated.
    I would plug the Kuuma Wood Furnace and if he is still in the design phase a placement in a room off the attached garage would make it easy to handle wood at any time.
    Insulation is lifetime of the home investment the furnace, wood burner, wood stove or wood boiler is going at some time to be replaced. Insulation makes that heating unit work less.... last longer.
    Its the builder in me coming..
    burndatwood, jeff_t, papadave and 2 others like this.
  6. brokenwing
    brokenwing
    Northern MD, Near the PA LIne
    I think a indoor wood furnace is going to be his best best, as it will be cheaper then a OWB, and he will still get even heat distribution through the house!
  7. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    We are heating 2200 SF ranch and 2200 SF basement (unfinished) with a stove located in the basement. This is our third year and we try to make insulation, window and door upgrades every year. We have used minimal oil in three years now. The biggest improvement was replacing the old garage service door. We just did not realize how much cool air the stove was drawing thru the service door. Has made a 2-3 degree change for the first floor. Holds heat all night now on just a bed of coals. So far this year temps on the first floor are definitely held in the 67-72 degree range with letting the stove burn down the coal bed over night. Rather than load the stove for an overnight burn, we open the air controls and burn the coal bed down to ashes. So my advise is a large wood stove and then keep making adjustments and improvements for the air flow and making design changes while you are in the pre-construction mode. How many cord do you have CSS at this time?
    Minnesota Marty likes this.
  8. Sam
    Sam
    Southern Minnesota
    I think many of us are missing the third option here...a forced air outdoor wood furnace. There are factory made options like this one http://www.menards.com/main/heating...furnace-2000-3000-sq-ft/p-1800853-c-12809.htm . For your setup I'd advocate putting a wood furnace in it's own little building right alongside the house and pipe in the warm air with a well insulated duct between the two. The only downside is that any time there is enough heat in the plenum of the furnace the blowers will need to run and you'll have (could be excess) heat. Some of the furnaces have forced draft blowers that rekindle the fire when a thermostat calls for heat so it can regulate the temperature somewhat. For those that do not have that feature one way to handle the excess heat would be what I call a "dump zone", essentially a duct that dumps all or most of the heat elsewhere until the thermostat calls for it. The thermostat would then operate a damper in the main duct to direct the air to the house or to the dump zone. Pretty simple HVAC stuff really, even though it sounds a little intimidating.
    The two 550's will be plenty but you'll have to size the duct work accordingly. It doesn't have to be perfect just reasonably so. I'd place the furnace in the middle (outside of course) of one of your long walls so the warm air will have equi-distance to travel to each end of the house. For your setup I'd advocate putting the furnace in it's own little building right alongside the house and pipe in the warm air with a well insulated duct between the two.
  9. Machria
    Machria
    Long Island, NY
    I haven't read the entire thread, but just a quick suggestion:
    Since you haven't built the house yet, why not design the house so it best fits a Wood stove as it's main heat source? That is pretty easy to do, I have some great design idea's on how I would like to do it. Your house design from a quick glance is about the worst design to have when it comes to wood heat.
    I would design a house which has a "great room" in the middle of the house, with the stove in that room. Have that room have a cathedral ceiling, the kitchen and family room would be part of this great room (separated by 1/2 walls if you like...). Then all the bedrooms and/or office would be on the 2nd floor, surrounding the great room. So the door to each room is facing the open stove room. So you basically have an open hallway on the 2nd floor going around the outside of the stove room, with rooms off of that hallway. The 1st floor which is basically 1 big great room gets it's heat from the stove heat being close by and in same room, the rooms upstairs all get the heat into the door way (and vents into each room) from all the heat which is rising and filling up the rooms. You can think of the rooms upstairs like lofts.
    Would be easy and cheap to build, bathroom on 1st floor would be up against the kitchen wall, and the 2nd floor bathroom would be just above that. So only 1 wall would require water pipes for 2 bathrooms and 1 kitchen.
    With this design, you can make this as BIG, or as small as you want based on your needs and budget. In addition, you could also adjust materials per you budget of course, using high end stones, tiles and granites or lower end cheaper building materials you can afford....
    Just a thought....
  10. Backwoods Patriot
    Backwoods Patriot
    Missouri
    I have redesigned the house layout already here check it out, see what you think!
    <iframe width="560" height="315" src="//www.youtube.com/embed/fUX7x3UNdqo" frameborder="0" allowfullscreen></iframe>
    burndatwood and wildwest like this.
  11. wildwest
    I prefer high cfm's on the fan, be it wood or pellet. I need the warm air moved around:)
  12. Machria
    Machria
    Long Island, NY
    Got it, looks MUCH better for wood heating!
    What software did you use to do the 3d rendering/design?
  13. sherwood
    sherwood
    Machria, with your theoretical design, what is UNDER the bedrooms???
  14. Machria
    Machria
    Long Island, NY
    The sides of the great room. All the rooms on the 2nd floor are basically just "lofts" around the outside (3 sides) of the great room. So the center of the great room goes floor all the way up to the roof (2 stories up). But on the sides of the great room, there are regular 8 or 10' ceilings suspended. A couple large beams would go across the entire great room to help support the "lofts".
    I have this all drawn up to scale in visio...
  15. Sam
    Sam
    Southern Minnesota
    Have you stayed in a house or cabin with open front lofts? I'd suggest a couple of test-runs before you commit to that design. It looks really good on paper, especially for heating and I love the actual look of it but in reality the open area is like a funnel for all the noise going on down below. We stayed in one with my wife's entire family over the xmas holiday and even with a 3/4 wall (horizontally not vertically) in the loft it was really noisy and I'm hard of hearing!
  16. Machria
    Machria
    Long Island, NY
    My design has full walls for the "loft" rooms. But they have vents up high on the wall a few feet long x 12" tall that can be opened or closed tight. That is how you control the heat in each room. Close or open the door, and/or vent to make it as warm or cool as you like in each room separately. I also have glass on that wall in each room, so you have a cool view down into the great room, that can also be opened if you like, and/or shut and privacy with blinds or drapes...
    Sam likes this.
  17. wildwest
    omg my 3 y/o went crazy over the music to the video!! What is that song? MUST HAVE. Dancing, marching, running, drumming, she LOVED it. Nice house too.
    LongShot likes this.
