Wood splitter question
Discussion in 'Chainsaws and Power Equipment' started by creek chub, Apr 14, 2020.
  1. In the Pines
    In the Pines
    get a wix or other quality filter. And forget about it for the next several years.
    Unless you put a lot of hours on it.. In which case you should have an hour meter and change accordingly.
  2. jmb6420
    jmb6420
    Grand lake, Oklahoma
    It depends a lot on how often and long you use your splitter. Service when using it a couple hours a month will be different than if you run it hard all day on a regular basis. The additives in hydraulic fluid wear out with heat and shear just like the motor oil in your vehicle. I always try to stick to the Mfg recommended interval. Everyone makes their own choices.
  3. creek chub
    creek chub
    Va
    I couldn’t find a part number for county line. I got a replacement one from tractor supply but it isn’t the exact one but the specs are close
  4. In the Pines
    In the Pines
    I can't recall the filter # I bought, I have to go look on the splitter. I'll try and remember tomorrow when it's light out between jobs.
    you have a new one and I'm sure it will be fine.
  5. brenndatomu
    My Champion calls for a Wix 51361 or Fram PH3942...I went Wix.
  6. In the Pines
    In the Pines
    I used a wix 51259, I ran out and looked real quick. Went with that for the higher gpm flow rate. It exceeds my countyline supposedly.
    With a little room for error when it eventually starts to clog up
  7. brenndatomu
    Looks like a good option if you have 1" threads...I have 3/4"
  8. In the Pines
    In the Pines
    that's interesting, I would think that all these kind of splitters would use the same kind of threads.
  9. jmb6420
    jmb6420
    Depends on size of the filter head used by the mfg. My 37 ton has 1 1/2-16 threads. It uses a physically larger filter WIX 51740 or I can save about $10 buying direct from Northern Tool.
  10. Meche_03
    Meche_03
    Missouri
    I think my Speeco uses similar filters.
    Automotive Filters 1"
    Length 5-13/32"
    Outside Dia. 3-11/16"
    Filter #s
    Fram 1653A
    Napa 1553
    Cross 1A9023
    Baldwin BT839 or BT839-10
    Wicks 51553 or 51552 or 51551?
    Different ones filter different particle sizes. Wicks is easy...last digit is x0 micron filtered. Others are around 30 to 25 micron. Baldwin is 30 micron -10 suffix is 10 micron.
    I went with Baldwin BT839-10 because it was cheaper at farm store.
    I'm fairly certain my splitter had never had the hydro filter changed since 2009. Oil looked and smelled good. Filter was starting to rust at thread flange. Spitter has always been stored inside.
  11. Meche_03
    Meche_03
    Missouri
    Donaldson P551327 is Thread Size - 3/4-16 UN
    Cross reference
    CARQUEST-84819 ,85545 ; FLEETGUARD-HF6351 ; FRAM-PH2815 ;NAPA-1545 ,7819
    Maybe others this is just what I found tonight.
    In the Pines and Screwloose like this.
  12. creek chub
    creek chub
    Va
    What splitter do you have?
  13. In the Pines
    In the Pines
    countyline 25 ton
    creek chub likes this.
  14. creek chub
    creek chub
    Va
    My tractor supply wasn’t much help identify the exact part. I found out ytl manufactures the county line splitters and contacted them.
    Pasted below is their response:
    Thank you for contacting YTL International and purchasing a Countyline Log Splitter. Tractor Supply stocks a Lenz CP-752-30 filter, SKU #1822617, or you can use a FRAM P1653A, or P1654A as a replacement filter.
    In the Pines and brenndatomu like this.
  15. In the Pines
    In the Pines
    I wouldn't buy a fram for my worst enemy fwiw. If you buy that wix I listed, it will fit your countyline. I never heard of lenz. But you can also cross reference that fram filter and find many other makes to use.
    brenndatomu and creek chub like this.
  16. brenndatomu
    Lenz is a decent filter...but I agree, just convert to a wix.
    creek chub and In the Pines like this.
