Wood on the ground, sort of?
Discussion in 'The Wood Pile' started by Marshel54, Aug 8, 2017.
  1. Marshel54
    Marshel54
    One of my stacks fell over, Mainly Ash and Beech. The stack is on a concrete pad. At this time it is low on my many to do priority list. Probably late Sept. to restack when I get into wood processing. Does on the dirt or on concrete matter? May have to move it up on the list if it matters.
    My thought is that the wood is spread out and will get more sun for drying. I am talking about probably a face cord of wood.
  2. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    If it were me, I would restack asap to keep the moisture from the ground getting to it.
  3. yooperdave
    How wet does your concrete get once it rains?
    Depending on what is going on (priorities) I would let it wait a bit too.
  4. Oldman47
    Oldman47
    Illinois
    Concrete will wick moisture but it will probably not move enough moisture to prevent the wood losing moisture while it sits.
  5. Marshel54
    Marshel54
    With all the discussion on ground wood, I didn't know about wood on concrete. Between have to get done and need to get done projects, not counting want to get done, I figure it will be late Sept. before I am back to wood making. Besides, with my system I am not sure what to do with this wood as far as restacking. I would like to move the beech to the barn for 2018 season, but haven't decided where to stack yet. Have this years wood done plus if needed more in the barn and a cord of oak and locus as part of my 3 year plan that I started. I may have to dedicate another area for 2 year wood.
    Backwoods Savage and MO. Wood like this.
  6. Marshel54
    Marshel54
    It use to be a dog kennels. When I poured the concrete, I made it so it had a slope and it drains well.
  7. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    If you can prevent the rain and nightly dew from hitting the wood, you should be okay. If sitting outside exposed to the elements, I would move it. You could lose the drying time it already has been through. In my opinion it absorbs water much faster thsn it dries.
    Backwoods Savage, Pazora and MO. Wood like this.
  8. FatBoy85
    FatBoy85
    Washington State
    Two schools of thought here, if its more exposed to sun in an even plane surface, its likely to be ok. But with wood that is told to punk easily with rain, you could just spread your stack out of the spill so its not as high but wider. Another row perhaps if you got the room but a picture would be nice to comment on here too.
    MO. Wood likes this.
  9. Backwoods Savage
    Well, if you weren't running all over the continent fishing all the time you'd have plenty of time left for work. :whistle: :rofl: :lol:
    If it were me I'd get it restacked ASAP. You are not talking about a lot of wood there so you are not talking much time at all. Then you won't have to wonder and if we happen to go into another wet period, which often happens in September, you will be all set.
  10. HDRock
    I'm with Dennis , just go re-stack it , a face cord won't take that long :):stacke:
    VOLKEVIN and Backwoods Savage like this.
  11. Locust Post
    I think you would be fine either way. It won't take that long to restack and it would bug me seeing it lay but on the other side of the stick wood is not a sponge and laying on concrete I don't think I would worry about it deteriorating any way shape or form.
  12. MikeInMa
    I'd restack. Now? No. But I'd get it done before the next time it rains. Once the rains stop and dries off, it'll still be wet under each split for a period of time. That's my 2 coppers.
    LongShot and Backwoods Savage like this.
  13. BigPapi
    BigPapi
    The hills of Western MA
    If it were me, I'd re-stack immediately so the wife doesn't get pizzed about the mess. :D
    She loves the free heat, and before tweaking her back something nasty on a scrounge even helped out a lot, but the bigger the hoard gets, the more picky she tends to be on neatness. Can't blame her really, we have a lot of road frontage and everything is pretty visible.
  14. yooperdave
    99 lbs sister, maybe?? :rofl: :lol:
    Backwoods Savage and BigPapi like this.
