Wood Boiler / Storage Shelter Ideas? Tips? before I build.
Discussion in 'OWB's and Gasification Boilers' started by LongPondPaperBoy, May 19, 2016.
  1. Kevin in Ohio
    Kevin in Ohio
    What I'm getting at is to get the best heat transfer you are supposed to have the flows going in opposite directions. At least that is what my supplier told me. Maybe others/experts will chime in. He said it is a common mistake to have the water directions going in the same direction. I did what I was told as I was all ears.
    Gasifier likes this.
  2. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    It's that how I have it now?
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  3. Kevin in Ohio
    Kevin in Ohio
    As I said before, I can NOT tell from your pic. Trace out the flow pattern and see if they are heading in the same direction or opposite. Opposite is wht I was told it needs to be.
  4. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    The return from the house is the top of the right side of heat exchanger. The wood boiler supply is on the bottom left. Is that correct. Wood Boiler supply bottom left of heat exchanger. Wood boiler return top left. Return from house top right going back in house boiler bottom right
  5. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    The picture is pretty clear
  6. Kevin in Ohio
    Kevin in Ohio
  7. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    Is there another picture I should take? [​IMG]
  8. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
  9. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    Left of house boiler is return. I take that water and go to top right of heat exchanger. I then go into boiler. I added a bypass as you can see
  10. Gasifier
    Do you know any HVAC contractors? Or someone who does a lot of boiler work? Most are not use to an add on wood boiler situation, but they may be able to help you make sure it is right before the cold weather gets here.
  11. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    Because these heat exchanger are so small the loss is minimal. Either way the heat will be exchanged. Does anyone have a picture of their heat exchange and boiler so I can compare? Did you cut into the return of your boiler?
  12. bushpilot
    bushpilot
    Eastern Washington
    This is quite important, it makes a big difference.
  13. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    I have not hooked up the boiler lines yet. I have many images of my install and I explained where everything is connected. Is what I am explaining not clear? I believe my setup is exactly what everyone is saying? Should I change something?
  14. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    The left side of heat exchanger flows bottom to top. The right flows top to bottom
  15. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    Another step closer. When will it end.......[​IMG]
  16. Gasifier
    When you are heating with wood, using no oil, and all is toasty when it is -10 outside. You and yours will be smilin! :)
  17. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    Working late. I am adding another motion light that will light up wood storage area. Should have power tonight
    raybonz and Gasifier like this.
  18. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
  19. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
  20. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    We are circulating water with the added chemicals. How long should I let it circulate before testing water?
