Wood Boiler / Storage Shelter Ideas? Tips? before I build.
Discussion in 'OWB's and Gasification Boilers' started by LongPondPaperBoy, May 19, 2016.
  1. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    raybonz, Eric VW and cnice_37 like this.
  2. cnice_37
    cnice_37
    Gloves and all, she looks ready.
    Eric VW likes this.
  3. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    Waiting for more pallets from a solar job to continue [​IMG]
    raybonz and Eric VW like this.
  4. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    All this wood cost me 100 bucks. It's been sitting covered for 4 years. [​IMG]
    raybonz likes this.
  5. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    Eric VW likes this.
  6. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    cnice_37 likes this.
  7. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    [​IMG][​IMG][​IMG][​IMG][​IMG] Installed pipes today. Found my downspout drain and sump pump drain
    raybonz and HarvestMan like this.
  8. Canadian border VT
    what are the depth of those pipes meaning above or below frost line?
  9. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    Depth is 24 inches.
  10. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    Maybe at frost line. I am from Boston area. 2 ft frost is average I believe
  11. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    Got a question. Once In the house. What type of pex should be used? Oxygen barrier or non oxygen?
  12. Sawdog
    Sawdog
    Not sure if this will help, but here goes.
    I built a wood shed around my OWB when I first installed it. Here's what I like and wished I had done differently.
    I wish it were bigger! This is always the case with any building, but true enough here.
    Concrete floor - it's strong, it's level, it won't wash away and I can sweep or blow it out
    I put a metal roof on mine - zero maintamence
    I have 10' ceilings - makes it hard to reach the wood on top if stacked all the way up
    I went 10x30 - wish it were bigger (did I mention that?)
    The OWB "bay" is 10'x10'. I wish I had more room around the boiler
    I should have put in a lockable storage area for my saws, oil, chains, etc (saws ain't cheap)
    Friend who owns Local saw mill milled the wood for me - cedar from old telephone poles - looks great to me
    Initially I wanted the back sided, glad I didnt get to that - I like the added air flow with it open
    If you are enclosing your OWB in a building, I'd make 100% you have enough draft to carry smoke outside when the door is open
    I should have gone bigger
    Hope this helps
  13. Canadian border VT
    So to rephrase Sawdog says go BIGGER!:D:yes:
    coal reaper and Sawdog like this.
  14. Sawdog
    Sawdog
    You sure are perceptive!
  15. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
  16. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    We got the heat exchanger tied in.
  17. Gasifier
    Glad to see your project is coming along LongPond. Looking good! I am going to ask you a question, not to be a pain in the azz, but to try to help. Is there a way you could add another 12" of dirt on top of your underground piping? Without putting the weight of a machine on top of them of course. Or some other way you could help with insulation factor of your pipes?
  18. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    There will be maybe 10 inches added to the top. I have 5 inches of loam to add plus I have to raise the grade up also
  19. Kevin in Ohio
    Kevin in Ohio
    Can't tell from the pic but you do have the heat exchanger hooked up so the flows are going in opposite directions don't you?
  20. LongPondPaperBoy
    LongPondPaperBoy
    Lakeville
    I have the supply from wood boiler on bottom on heat exchanger. The return from house is on the top. Will that work?
