Winter Small Engine Storage: Gas Full (w. Stabil) vs Gas Empty
Discussion in 'The DIY Room' started by Dumf, Nov 9, 2020.
  1. raybonz
    raybonz Moderator
    Carver, Mass.
    Always treat my fuel with Sta-Bil and last week decided to start my generator to ensure readiness.. Generator would not run then the pull cord snapped followed by the recoil spring breaking and found a clearish gel in my carburetor fuel bowl followed by a leaking carburetor bowl gasket.. Other than this it was great lol..
    Cleaned out the bowl and flushed out the carb and removed the jet and cleaned and blew that out. Removed the recoiler and noticed a nut securing the fan wheel on and decided to use a 24mm deep socket on my 7.5 amp electric drill and cranked the engine until it started..
    While I let the generator run I went down cellar and managed to cut the recoil spring and cut back the pull cord and that was working again after an hour or so.
    In the process of removing and replacing the carb bowl the gasket got mangled. It is damm near impossible to install this gasket without it falling off! I designed and 3D printed a gasket using TPU (thermoplastic polyurethane) that fits onto the bowl side with a locating lip to keep it centered on the bowl and this worked like a charm and made it easy to reinstall.
    At the advice of a small engine mechanic I am switching to Startron enzyme fuel treatment because Sta-Bil let me down. He swears by it!
    Attached is the old gasket and the new one I created.
    M2theB, milleo, bogieb and 3 others like this.
  2. brenndatomu
    This ^ ^ ^!
    Sta-Bil doesn't deal with the ethanol...unless you buy the specific ethanol formula Sta-bil...which is kinda hard to find.
    M2theB, bogieb, MikeInMa and 2 others like this.
  3. brenndatomu
    Nice work! :yes:
  4. raybonz
    raybonz Moderator
    Carver, Mass.
    Thanks!
    M2theB, Elvisss222, bogieb and 2 others like this.
  5. Highbeam
    Highbeam
    If you had just slapped the tank 3 times this wouldn’t have happened.
    huskihl, M2theB, Farmchuck and 4 others like this.
  6. raybonz
    raybonz Moderator
    Carver, Mass.
    LOL apparently I screwed up!
    Farmchuck, bogieb, Highbeam and 2 others like this.
  7. Highbeam
    Highbeam
    I’ll stop, sorry. I’ve been very lucky to never have any of these types of problems. I store my equipment indoors, store fuel indoors, treat all fuel with stabil, and it all just works. I guess it’s just luck and superstition.
    M2theB, bogieb, Erik B and 2 others like this.
  8. yooperdave
    Must be getting sore?
    bogieb, Highbeam and brenndatomu like this.
  9. Warner
    Warner
    Accidentally hit the hot exhaust?
  10. brenndatomu
    Anybody ever accidentally get against the spark plug on one of those old Briggs engines that didn't have a rubber spark plug cap?
    Hate to be slapping one of those tanks and miss! :eek: :eek: :eek:
    bogieb, raybonz and yooperdave like this.
  11. Highbeam
    Highbeam
    Ive been zapped on spark plug wires, my hands of course, and ever since then I refused to “kill” the Briggs engines with that little metal tab on the spark plug that you were supposed to push down to ground the spark. Always poked it with a stick.
    raybonz, bogieb and brenndatomu like this.
  12. Highbeam
    Highbeam
    i don’t want to hurt the feelings of people that really believe in the various superstitions. It’s like a religion to some folks.
    yooperdave, bogieb and brenndatomu like this.
  13. metalcuttr
    metalcuttr
    western WA
    My chainsaws and Weedeater and blower use Trufuel and I store them full. Never a problem. The generator, log splitter and outboards all get E- free and Stabil. I store them full but pull them out about once a month and run them til hot. I put the outboards in gear when running to wet all the seals and coat the gears. Everything but the big outboard are stored inside.
    bogieb and yooperdave like this.
  14. Lastmohecken
    Lastmohecken
    Arkansas
    I always run 100% gas, no alcohol in everything. I don't run anything dry. The main issue I have is keeping the batteries up on everything. I try to remember to start everything a few times during the off season and run it a while, this helps. But, I better check my weedeater and leaf blower, as I have not run them for months. I might be in trouble there, I don't know.
    I do know I have a motorcycle battery that's dead and my welder battery tends to run down on me, if I am not using it much, but both batteries are old.
  15. Highbeam
    Highbeam
    Super cheap battery tenders are available at harbor freight. I have my mower on one all year. Hope they’re okay. So far so good.
    Sandhillbilly, bogieb and yooperdave like this.
  16. bogieb
    I don't have any yard tools with batteries - well not true, but those are Ryobi one+ where I keep the batteries in the house anyway and used them for several different tools. But my bike is on a battery tender. I put a new battery in it early last spring and want to keep it in good shape.
    Highbeam, brenndatomu and yooperdave like this.
  17. raybonz
    raybonz Moderator
    Carver, Mass.
    Some say they tend to overcharge.. Might want to check the charge voltage.. I take my rider mower battery in for the winter...
    bogieb, brenndatomu and yooperdave like this.
  18. brenndatomu
    The cheap ones can...I use the Battery Tender brand for that reason...nothing like the process of keeping your battery from going bad, making your battery go bad! :hair:
    raybonz, MikeInMa, Highbeam and 2 others like this.
  19. bogieb
    For my bike, went with the HD tender - yeah, more money but they are definitely meant to go with the battery I have.
  20. brenndatomu
    I'm sure its a good one if they are selling it under their name...probably the same as mine with a different label.
    raybonz, bogieb and yooperdave like this.
