Why?
Discussion in 'Everything Else (off topic)' started by FarmerJ, May 24, 2023.
  1. eatonpcat
    I may be guilty of this!
  2. Screwloose
    Screwloose
    A lot of people are!!
  3. Dok440
    Dok440
    NorCal
    I blame it on the ethanol added fuel. Joe consumer buys OPE, runs it a few times and puts it away for next year, full of fuel. Next year that carb is clogged and maybe the rubber is already cracked from the fuel sitting all year. To Joe consumer, that OPE is still "new"! Surely it just needs some starting fluid and once it runs it will run like it did last year. A little doesn't help so a little more will do. Now ol' Joe is mad and the can is emptied down the carb. I can see it.
  4. moresnow
    moresnow
    Go grab a can of fresh air is what we called it years ago with stubborn starting Cat heavy equipment. There was always a case in the job trailer. Right next to my GPS equipment. Interesting mix of responsibilities:)
    Never poofed a motor. Sure made some rattle if you were to "give er" too much!
    Never ever used the stuff in the 2 strokes. Terrible idea.
    T.Jeff Veal and brenndatomu like this.
  5. Jeffrey Svoboda
    Jeffrey Svoboda
    I've drove many a no start tow ins on brake clean at the dealer i used to work at. Pull the air intake tube and make someone sit under the hood pulsing brake clean into the throttle body while another drives. Just don't let the driver touch the throttle or you'd likely get a fireball blown back at ya if you're the guy under the hood with the can.
  6. Warner
    Warner
    Guy at the place I worked at used a couple cans to clean out the plastic manifold on a wind star. Guess what when he started the motor the leftover BK ignited and blew the intake clear off the motor! :thumbs::rofl: :lol:
  7. T.Jeff Veal
    I remember that. My cousin had a 4230 that I drove many hrs. He also had a 4320 earlier and 4640 later, he got a 4840 after engine trouble with the 4640
  8. Canadian border VT
    After reading that post I know 1 thing for sure…
    Model number at JD are not dyslexic friendly
  9. brenndatomu
    JD does have a system on models numbers, for the farm tractors anyways, the larger the first number(s) the larger the tractor, the larger the last two numbers, the newer the tractor...roughly.
  10. Casper
    Casper
    Glocks have always confused me.
  11. Eggshooterist
    Eggshooterist
    Erff
    The hole points away from you...
    spotted owl, Softwood, Ron T and 8 others like this.
  12. eatonpcat
    T.Jeff Veal, Chaz, Screwloose and 3 others like this.
  13. Casper
    Casper
    Half the Glock 10mm I've shot have blown up in my hand. 20210619_191627.jpg 20210619_191600.jpg 20210619_123346.jpg
    Many tiny little shards of breech-face and Glocks special coating embedded in my thumb.
    It took two weeks to get the last little annoying piece out. I used a Streamlight Stinger as my "imaging" tool.
  14. Eggshooterist
    Eggshooterist
    Erff
    Not cool. My cousin had a Taurus 1911 blow up in his hand. He got lucky as well.
  15. Eggshooterist
    Eggshooterist
    Erff
    What did Glock have to say about that?
  16. Casper
    Casper
    It was a buddy's, he claims the loads were factory, but I suspect they were his reloads. I think Glock charged him to repair it from what I can remember. That kind of tells me my hunch may have been correct.
    Sorry for the thread drift FarmerJ
