Who's Using A Grapple ?
Discussion in 'Chainsaws and Power Equipment' started by HoneyFuzz, Jan 27, 2022.
  1. FarmerJ
    FarmerJ
    Minnesota
    Use the grapple to put them onto a bunk table of other wood then cut them up
  2. T.Jeff Veal
    Check out these grapples...
    Attachments — MTL Attachments
    Some of these are heavy duty enough for that size tractor.
    I have good visibility with this grapple, even with it not being as wide as the tractor... 0119231319.jpg 0119231152a.jpg
    I like the flat bottom tines, works almost like forks, hold a log while leaving the top open.
    You can hold a big round like this, to place on a splitter or trailer 0207230913.jpg
    It has a 40-41" jaw opening, for bigger logs... 0119231153.jpg 0406231011_HDR.jpg
    I looked at the EA Wicked grapple, nice grapple, but I was able to get the MTL grapple and a set of forks a bit cheaper than just a grapple from them.
  3. Farmchuck
    Farmchuck
    Nepa
    I cut from the ends until i come to my forks with the log suspended to save my back. Then I open the grapple with the piece thats left on the forks and finish cutting it. My grapple is different though than grapple shown on those tractors.
  4. Farmchuck
    Farmchuck
    Nepa
  5. Farmchuck
    Farmchuck
    Nepa
    Very hard to see where forks are in relation to logs from tractor seat. I wind up making ruts with the fork tines which is a pain.
    EODMSgt, T.Jeff Veal and HoneyFuzz like this.
  6. jrider
    jrider
  7. Farmchuck
    Farmchuck
    Nepa
    The local borough took some trees down & brought me the wood. They dumped it in the grass. Here’s my problem: 9EB9C9D4-FB73-4513-82AA-88B43B3CD2E0.jpeg E584D005-7C6D-4C33-9700-9D3F1A30EEE1.jpeg 0F5879C5-327C-4AB4-9F75-C6EDC0F255CD.jpeg
    Barcroftb, fuelrod, EODMSgt and 4 others like this.
  8. Chud
    Chud
    NC
    I see where that flat metal between the top forks would really obstruct your view. I can stand up and see where my bottom forks are, but I don’t like to. I prefer from the top down log picking.
    Barcroftb, EODMSgt, Farmchuck and 3 others like this.
  9. EODMSgt
    EODMSgt
    White Mountain Region, NH
    I cut the log until the grapple gets in the way, then depending on the size, I'll just put the remainder on runners and cut it the traditional way. If the remainder is of a good size, I'll measure and make 3/4 cuts, then use the grapple to rotate the log to make the rest of the through-cuts. With forks, I was able to usually make all my cuts with the log on the forks, however I find (for me) it's much easier and faster to use the grapple once you get used to it.
    jrider, HoneyFuzz, Farmchuck and 2 others like this.
  10. jrider
    jrider
    I can see this. Much quicker and easier to grab the log with the grapple but a little cumbersome to cut a full log on compared to forks.
    Farmchuck, EODMSgt and T.Jeff Veal like this.
  11. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
  12. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
  13. T.Jeff Veal
  14. Chud
    Chud
    NC
    Forks are useful for picking poles.
  15. T.Jeff Veal
    Barcroftb, HoneyFuzz and Chud like this.
  16. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    When the ditching / grading bucket was left too far away...grapple to the rescue !
  17. Barcroftb
    Barcroftb
    The Mitten
    A little grapple action here yesterday. Just a little 16” dbh green box elder trunk. IMG_4534.jpeg
  18. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Nice ! Grappling the the Y-pieces is always interesting. Nice work !
  19. Barcroftb
    Barcroftb
    The Mitten
    For sure! Trick is finding the balance point. Fortunately I’ve had lots of practice with rigging branches for tree work.
    MikeInMa, eatonpcat, Chvymn99 and 2 others like this.
  20. FarmerJ
    FarmerJ
    Minnesota
    This is a perfect picture of why I like the double clam grapples
