Whoops...
Discussion in 'Chainsaws and Power Equipment' started by SKEETER McCLUSKEY, Apr 3, 2018.
  1. T.Jeff Veal
    That happened to us a couple yrs ago, on the first day we started cutting oak trees on that Plantation job. Drove over a small top on there went the valve stem. Rear tires are fun when full of ballast.
    John D, JD Guy, Screwloose and 4 others like this.
  2. isaaccarlson
    isaaccarlson
    Colfax, WI
    We had to dig the hole to bury Nova this last week. The ground was frozen solid almost 2 ft deep. I had to jackhammer the bobcat forks into the frozen ground and pop out chunks. We made it through the frost and the variable speed seal blew out. I barely made it back to the driveway. Now I have to track down the parts and get it put back together. I don’t know why they used ~1/4” thick o-rings. Would have been much simpler with regular o-rings.
  3. Canadian border VT
    We have totally different definitions of the word fun!
    I like fact my tires are not loaded; have 150# weights each side.. to put on chains let out air put on chains add air and they are tight
  4. Ward Hoarder
    Ward Hoarder
    West Virginia
    310 pounds of ballast.
  5. Skier76
    Skier76
    CT and SoVT
    Remember that snowmobile I put a brand new top end in 2 years ago? Pitons, rings, bearings, cylinders…..
    Less than 10 miles later:
    I have to figure out what the issue is before I start launching the parts cannon. 90 psi on this side, 120 psi on the other. It’ll run enough to get it on the trailer and bring it back to the flatlands.
  6. Canadian border VT
    2 cycle my guess line that pumps oil into gas is bad.. straight gassed
  7. Skier76
    Skier76
    CT and SoVT
    Correct! 2002 Arctic Cat Z570. Last time it burned down, I found safety wire connecting the oil line to the pump and it was leaking. Fixed the line, OEM connector and I thought it was good to go…
  8. Canadian border VT
    Experience is a good but cruel teacher :headbang:
  9. brenndatomu
    Most people delete the autolube oil pump and just premix the fuel once they start causing trouble
  10. Ward Hoarder
    Ward Hoarder
    West Virginia
    I can't like this.
  11. isaaccarlson
    isaaccarlson
    Colfax, WI
    I trusted the oil pump in my jet boat and burned it up. The next motor will get premix.
  12. Dok440
    Dok440
    NorCal
    This!
    metalcuttr, John D, Skier76 and 4 others like this.
  13. Skier76
    Skier76
    CT and SoVT
    That’s probably what will happen. Usually those pumps are pretty reliable.
    This sled was a first year for this engine. Some part numbers changes on 2003 and up. Some say the CDI runs hot, some say the oil pumps aren’t good…
  14. Skier76
    Skier76
    CT and SoVT
    Tree didn’t go where I wanted it too. My wife was eyeing a new patio set, so only real damage was to my pride.
  15. stuckinthemuck
    stuckinthemuck
    Cast Aluminum? Get a Maasdam kit. $160 of cheap insurance. For your pride. Glad the damage is minimal and no one was hurt.
  16. Screwloose
    Screwloose
  17. Skier76
    Skier76
    CT and SoVT
    Thought about setting something like that up. Hindsight is 20/20!
  18. T.Jeff Veal
    Glad it was just the patio set and not the house.
    metalcuttr, Skier76, John D and 5 others like this.
  19. Skier76
    Skier76
    CT and SoVT
    My wife said the same thing! Coulda been much worse.
  20. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Im impressed the saw did that to the furniture after the tree had a go at it. ....
    Tree safely on the ground though. Thats good.
