Whoops...
Discussion in 'Chainsaws and Power Equipment' started by SKEETER McCLUSKEY, Apr 3, 2018.
  1. fuelrod
    fuelrod
    Western Maine
    $260 little baby alternator!
    I can't really complain. I bought this used F- 2000 from a commercial cutter 38+/- years ago! It's spent a couple of hours at about 8' under water in my pond along with a lot of grass cutting, and just a tough old girl in general. Basically a little "B" model with the seat turned around. :D
    Chaz, Stephiedoll, Screwloose and 8 others like this.
  2. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    That's a dynamo
    Chaz, Screwloose, eatonpcat and 4 others like this.
  3. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    It's similar to teriyaki
  4. fuelrod
    fuelrod
    Western Maine
    That's what Messicks site called it too. :eek: what's the the difference. I know mine is locked up tight.
    Chaz, Screwloose, eatonpcat and 2 others like this.
  5. FarmerJ
    FarmerJ
    Minnesota
    Kinda like a magneto but for generating electricity. A “permanent magnet alternator” is another way to consider it. More akin to a 6-volt generator off an old John Deere B model or similar.
    Chaz, Screwloose, JD Guy and 4 others like this.
  6. Buttermilk
    Buttermilk
    Central AR
    20230713_125626.jpg I think with a little turtle wax and a few zipties it'll be fine.
  7. Haftacut
    Haftacut
    Rives Junction, MI
    Not really an oops, but I put a new clutch disc in the chipper, flipped the knives, and adjusted the anvil. Crazy how you kind of forget how good it can chip:rofl: :lol: Guess it’s kinda like the whole frog in boiling water concept. Not gonna win a beauty contest, but she’ll eat! FC4AA26C-E984-4A1B-98C7-E943C37055E2.jpeg 48E4D379-5FB0-45FD-A640-B983FEC3E48E.jpeg
  8. Screwloose
    Screwloose
    Engineer oopsied on specking a pump. This started out at 11 1/2" diameter!!
  9. Screwloose
    Screwloose
    Okay so a simple explanation of the difference is......
    A dynamo and generator are the same thing and can be permanent magnet or wound. They have commutators (segmented parallel bars) and produce DC directly.
    A alternator produces AC and is rectified to DC. It has slip rings ( continuous rings and brushes).
    A magneto has a generator, ignition coil and distributor all in a ready to eat package.
    Clear as mud.
    Edit, all this means nothing as it's terminology is mixed up like motors and engines.
  10. chris
    chris
    SE WI
    always considered a motor to be electrical, ICE -powered by a fuel source, liquid, Vapor or solid. ECE still requires a fuel source also.
  11. brenndatomu
    Same here...but then you get some wise guy that says "so why do they call it "motor oil"? :picard: :hair:
  12. Screwloose
    Screwloose
    I always understood it as motors were current carrying weather electric, hydraulic, air ect.
    Engines were fuel powered but then the term "engine lathe" always rubbed me wrong.
  13. eatonpcat
    What does the weather have to do with anything??
    Chaz, T.Jeff Veal, Softwood and 2 others like this.
  14. brenndatomu
    Electric motors shouldn't be used in the rain...engines can be :D
  15. Screwloose
    Screwloose
    Still better than wether.....at least for the animal.
    In some cases I'm even beyond the help of auto-correct.
    Chaz, JD Guy, eatonpcat and 3 others like this.
  16. eatonpcat
    Yes sir! Both close enough, just giving you a hard time!!
  17. fuelrod
    fuelrod
    Western Maine
    I have bearings coming today for my dynamoternator or altermo:D.
    Hopefully I'm cutting grass tomorrow. :thumbs:
    The clover in our "lawn" is irresistible to the porcupines and is a one way ticket to the train station for them. Our dogs and porcupines don't mix.
  18. fuelrod
    fuelrod
    Western Maine
    She lives on! For under $30.
    There's 3 little sealed bearings, all the same. About 15 minutes to reassemble it and another 15 to install it and a new belt. :thumbs:
    The grass is cut.
  19. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    let that be a lesson to everyone:BrianK:
  20. T.Jeff Veal
    On one on the calciner systems I operate, we have a Hosakawa 200ACM mill. They don't know if something came loose Sunday as it was shutting down or Monday on startup, but it tore the mill up and locked it down, probably an 80k rebuild at least.
    More hammers and parts. The hammers were at 90°, a little past that now... 0809232240.jpg
    The separator/classifier has some normal wear, but it got bent too. 0809232240b.jpg
    Thankfully we had all the parts to rebuild it...
