Whoops...
Discussion in 'Chainsaws and Power Equipment' started by SKEETER McCLUSKEY, Apr 3, 2018.
  1. brenndatomu
    Nah not really...I've done it...the thing is it's a small fastener, so the welding goes fast...but I would mig weld it on a fairly low amperage
  2. Warner
    Warner
    Yup what he said. Clean up the top of the broken bolt real good. 441C6013-A687-4C5C-BE8F-921F18D62B7E.jpeg Depending on the situation I might use the angle grinder and carbide bit to get rid of some of the oxidation around the fastener and the air hammer with the flat bit to tap on the broken bolt. Get lots of nuts and don’t get discouraged when a few don’t stick well. When you get one to stick and the bolt moves work it back and forth small gains at a time.
    Side note this guy does some cool chit
  3. T.Jeff Veal
    Glad that stump didn't get the truck
    metalcuttr, Screwloose, Ron T and 2 others like this.
  4. Screwloose
    Screwloose
    Even though the melting temperature of aluminum is lower the heat dissipation is 5 times faster than steel. It actually takes more power to weld aluminum than to weld steel.
  5. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Morbark chipper,rear engine mount bolts snapped off in pto adapter ring 20230620_112238.jpg
  6. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    fuelrod, FarmerJ, savemoney and 6 others like this.
  7. brenndatomu
    That's what I say too "dunno why these things wanna fight me like this, in the end I always win!" :hair: :rofl: :lol:
  8. Buttermilk
    Buttermilk
    Central AR
    Just run it till all the blade trunnion bots are missing and the shims fall out. It will still gps just fine.lol 20230627_080933.jpg
  9. Buttermilk
    Buttermilk
    Central AR
    Washing condenser out this morning. It was 102 here yesterday and he complained that it wasn't cooling good. Pressures were spot on and when I looked at the condenser it was so dirty I couldn't see it. 20230629_061353.jpg
    fuelrod, Chvymn99, eatonpcat and 7 others like this.
  10. Buttermilk
    Buttermilk
    Central AR
    Since I swapped jobs I won't have pics of those 200,000 pound machines. Here the biggest track hoe is a 160 and that is a go
    fuelrod, Chvymn99, Screwloose and 3 others like this.
  11. Buttermilk
    Buttermilk
    Central AR
    Hey SKEETER McCLUSKEY, do you know if you have to time the engine on a jd 50g excavator to remove the fuel injection pump. Thanks Brad. JD dealer is not much help.
  12. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    I believe so,is it a 4TN yanmar?
  13. Buttermilk
    Buttermilk
    Central AR
    Yes sir. I have since found the timing procedure. Thank you for the replie.
    Chvymn99, Screwloose, Chaz and 3 others like this.
  14. buzz-saw
    buzz-saw
    Ct.
    None that I have had a problem with.
    I have done this numerous times on aluminum , I just did a broken bolt in an outboard motor last week.
  15. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    I have the 4TN tech manual here if you need anything else....
  16. Buttermilk
    Buttermilk
    Central AR
    May hit ya up on that
  17. Buttermilk
    Buttermilk
    Central AR
  18. Buttermilk
    Buttermilk
    Central AR
  19. T.Jeff Veal
    Screwloose, JD Guy, eatonpcat and 5 others like this.
  20. T.Jeff Veal
    I think we got the good out of this pulley. Good news, we put a new deck belt on Thursday morning, cut that morning, and my wife started cutting our grass that afternoon. It frayed the bottom edge of the belt but didn't cut it. And they had one in stock...
