Whoops...
Discussion in 'Chainsaws and Power Equipment' started by SKEETER McCLUSKEY, Apr 3, 2018.
  1. Warner
    Warner
    D40C415C-B76E-42CD-AB56-95CFAF29A3AB.jpeg :bug:Noticed this walking across the parking lot!
  2. Warner
    Warner
    26181513-0AE7-46FB-8D0F-E580D3B09353.jpeg Smells like crackhead under here!
  3. Skier76
    Skier76
    CT and SoVT
    Helped my neighbor remove the blades from his mower up in VT. The DeWalt 1/2” impact made the removal really easy.
    Our ramp system that could have ended up in a “whoops”…but thankfully didn’t. My wife: “You actually got under that?”
    :whistle:
  4. T.Jeff Veal
    Looks like the same impact we have/ use to change our blades.
  5. Screwloose
    Screwloose
    Dang!! Them some used blades!
  6. buzz-saw
    buzz-saw
    Ct.
    Holy crap :bug:
    Talk about getting your money's worth out of a set of blades.
    Next time he cuts the grass it will take less time since the new blades will be a little longer.
  7. brenndatomu
    I think those are the most whooped blades I've ever seen!
  8. Skier76
    Skier76
    CT and SoVT
    I don’t think he’s taken those off since he’s had the tractor. I want to say that tractor is a good 12+ years old. Granted, it’s a weekend property and he’s not up every weekend. But still, they are well used!
  9. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  10. Screwloose
    Screwloose
    At what point would it start leaving a strip of unmowed grass....
  11. brenndatomu
    About 8 years ago is my guess!
  12. Ron T
    Ron T
    Northeast Ohio....Bowdil
    I'll jump in here. Didn't see the stump on the way out from cutting this morning. Didn't touch the truck luckily. 20230611_113127.jpg
  13. Ron T
    Ron T
    I'm partial to a truck without steps :whistle: 20230611_132039.jpg
  14. Chud
    Chud
    NC
    Only 200hrs on the oe clutch
  15. Chvymn99
    That your new baby? What happened?
  16. Chud
    Chud
    NC
    No sir, my baby doesn’t have a stick, has way more than 200hrs and is still in one piece.
  17. Screwloose
    Screwloose
    Some people should never go near a manual........
  18. stuckinthemuck
    stuckinthemuck
    What’s the best way to get these broken bolts out?
  19. brenndatomu
    I'd weld nuts on...or sometimes on small bolts, or stuff that is hard to get to, welding a flat washer on, then a nut works better.
  20. stuckinthemuck
    stuckinthemuck
    Is there any issue using that method removing a steel bolt from an aluminum case? Just thinking that the melting point of aluminum is much lower. Thanks
