Whoops...
Discussion in 'Chainsaws and Power Equipment' started by SKEETER McCLUSKEY, Apr 3, 2018.
  1. Warner
    Warner
    4110 and that one isn’t slated for retirement just happens to be there.
  2. T.Jeff Veal
    Found another hole with no bottom yesterday...kinda wet down here in GA... 31851.jpeg
  3. brenndatomu
    Oh, there's a bottom...you just ain't found it yet! :hair:
  4. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  5. Warner
    Warner
  6. Warner
    Warner
  7. Chud
    Chud
    NC
    Slippery when wet
  8. Skier76
    Skier76
    CT and SoVT
    Yikes! Hope they were ok.
    Needs more caution tape. ; )
  9. T.Jeff Veal
    Somebody had a slight "oh, crap" yesterday on GA 540, right outside Sandersville.
    Don't know what happened, didn't
  10. corncob
    corncob
    Somewhere in Lower Michigan
    Pretty typical with a hoper bottom and grain but typically they don't break in two like that. Every farmer I know (including myself) overloads a hopper bottom. You want to haul as much as possible to the elevator in one trip. Hopper bottoms are pretty strong to begin with but will break if severely overloaded and really, there is no practical way to ascertain how much product you put in one other than knowing how full is 'full' No scale here at the farm so it's all visual and certainly no scale in the field when direct loading from a grain cart or combine.
    That hopper bottom was grossly overloaded. I've grossed close to 100 grand on 5 axles in the past, or 20 over gross. I can visually tell how much is in the trailer or at least close. My Timpte has level windows in the side to see how much product I have inside.
    As a rule around here, the weighman turns his head and ignores hopper bottoms, they all know we are heavy but they also know the fewer trips to the elevator the faster we get it done.
    The owner of the unit will have to pay for the remediation no matter what. How it works.
  11. Warner
    Warner
  12. Jeffrey Svoboda
    Jeffrey Svoboda
    Well.... ya know..... that guy at the parts store said i could use them and it would be just fine. :headbang:
  13. brenndatomu
  14. Warner
    Warner
    There are 4 of them within 6’ on the same line! :rofl: :lol:
  15. Jeffrey Svoboda
    Jeffrey Svoboda
    Someone really knows how to think things thru. :hair:
  16. Screwloose
    Screwloose
    That's definitely a no no!
    In Wisconsin you are required to wrap compression fittings with duct tape.
  17. brenndatomu
    That's kinda like when we use stainless band clamps to repair underground leaks on cast or DI water distribution lines...once a crack has progressed to the point where you eventually have a bunch of SS clamps butt to butt for a ways, they just say that part of the line has been upgraded to SS :picard: :rofl: :lol:
  18. T.Jeff Veal
    Started cutting a limb crotch from a pecan tree. Never saw anything on the outside of the tree, but the chain sure quit cutting...:headbang::headbang:
    0310231402.jpg :doh::picard:...it should just buff out, right??? 0310231400.jpg
  19. JB Sawman
    JB Sawman
    pennsylvania
    Does that work like one of those clamp on sharpeners just hold it against the rock and it will self sharpen :rofl: :lol:
  20. T.Jeff Veal
    Not quite...lol...
    I think I rescued that chain today...
    3 passes around the grinder, then set the rakers. Not quite perfect yet, but I think it will cut. 0311231330.jpg
