Whoops...
Discussion in 'Chainsaws and Power Equipment' started by SKEETER McCLUSKEY, Apr 3, 2018.
  1. JB Sawman
    JB Sawman
    pennsylvania
    I really do not know what I do know is it did no belong in the boom in the first place the serco dealer said it should be a long 2 inch bolt with step down threads with a castle nut when I looked at the boom in the daylight someone had welded a nut to the boom and put this pin in which had a retainer plate welded to one end to hold it in place with a small bolt I will get some pictures when the new pin comes in the pin hole right behind the log upright in between the hoses is where it broke out he was in the middle of loading when it happened DSCF2072.JPG DSCF2073.JPG
  2. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  3. Warner
    Warner
    That’s a regular Monday morning around here:rofl: :lol::rofl: :lol::rofl: :lol:
    where do you get the rubber on the bottom of the boxes?
  4. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Buyers products
  5. Ward Hoarder
    Ward Hoarder
    West Virginia
    Serious dust issues
  6. fuelrod
    fuelrod
    Western Maine
    Who ever said that "close only counts in horseshoes"?
    3-4" and that truck wouldn't be there. :headbang:
  7. buzz-saw
    buzz-saw
    Ct.
    :eek: Yeah you think.
    That third picture is a little scary.
  8. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Municipal salt spreader auger hydraulic motor no workie......they chewed completely thru the yellow wire 20221117_075745.jpg
  9. fuelrod
    fuelrod
    Western Maine
    I hate "they"! That reminds me to set up their swimming pool/teter totter.
  10. Screwloose
    Screwloose
    If you pour a little water into the motor it will help keep the dust down.
  11. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Like cleaning a 480 box with a wire brush
    T.Jeff Veal, eatonpcat and Screwloose like this.
  12. Screwloose
    Screwloose
    While standing in a puddle.....
  13. T.Jeff Veal
    I would say so.
    brenndatomu and Screwloose like this.
  14. T.Jeff Veal
    A couple whoops today...
    We were using the conveyor to load the trailer from a shed yesterday, almost done, and the belt slows way down, stops and starts slow again. I thought the set screw on the coupling between drive unit and roller was loose. Took it apart this morning, chinesium parts failed...
    But the conveyor was free when we got the splitter....
    Thinking of welding to coupling to the roller, what y'all say?
    Chvymn99, fuelrod, Boogeyman and 3 others like this.
  15. Erik B
    Erik B
    Western Wisconsin
    T.Jeff Veal Good to see another hoarder here who believes the job isn't done right until you bleed on it.:thumbs::thumbs::pain::pain: Happens all the time with me.:handshake:
    Softwood, Chvymn99, Haftacut and 5 others like this.
  16. brenndatomu
    I usually reserve that for last resort type stuff...but its up to you. If you have to replace everything anyways, might as well...
  17. Screwloose
    Screwloose
    So the coupling just attached the drive to the roller with no bearing in between ? If so I'd say weld it as you can always replace the shaft in the roller at a later date.
    Chvymn99, T.Jeff Veal and brenndatomu like this.
  18. T.Jeff Veal
    Lol...I thought I had deleted that picture. I did that later in the morning, got it caught between 2 logs on the tractor forks. Glad I had my gloves on.
    Stephiedoll, Erik B, Chvymn99 and 3 others like this.
  19. T.Jeff Veal
    That's correct, the hydraulic drive motor is the support for that side of the roller. Wish I could put a lovejoy type connection on it.
  20. T.Jeff Veal
    Brought the roller to work tonight, my shift mechanic drilled and tapped 2 holes in the coupling. Got 1 in the old key way on the shaft, other 90° to it. Installed bolts and lock nuts.
    We'll see how this works. At least it will be easy to take coupling off to replace shaft later. 1122220429_HDR.jpg
