Whoops...
Discussion in 'Chainsaws and Power Equipment' started by SKEETER McCLUSKEY, Apr 3, 2018.
  1. Warner
    Warner
    New tire hit a piece of metal sticking out of the bridge joint at 65 mph on the interstate. There were 6 other vehicles on the side of the road with flats. I keep going 2 miles to the service plaza. Wasn’t changing it in the dark on the road side.
  2. stuckinthemuck
    stuckinthemuck
    Was it on the way to a job site, or were you doing some work on it?
  3. Warner
    Warner
    On the way to the pour, I had all the equipment on the truck to make it happen. Learned to “be prepared” long ago.
  4. stuckinthemuck
    stuckinthemuck
    Did the steel belt get caught up in the hub? using the strap to pull it out?
  5. Warner
    Warner
    Belt was stuck between the backing plate and axle. I tried yarding it out with the strap but ended up cutting it with my battery angle grinder.
  6. Warner
    Warner
    Still made it to the site before the concrete truck. Winning!
  7. stuckinthemuck
    stuckinthemuck
    On time is late. 30 minutes early is on time. Good that you had some extra time built into your plan.
  8. TurboDiesel
    Yikes!
    Thats scary stuff!
  9. TurboDiesel
    Thats better than a bridge collapse though!
  10. stuckinthemuck
    stuckinthemuck
    That all depends on your agenda…..
  11. Warner
    Warner
    Believe it or not it’s not uncommon for the metal that the membrane is attached to to come loose.
  12. Warner
    Warner
    Yep, my MO is to be there 2 hours early. Travel is usually over an hour from hq. anything can happen. The work for the day could not be completed without the machine I’m towing. Ton of problem solving involved gotta be quick on you feet!
  13. stuckinthemuck
    stuckinthemuck
    You did well my friend. And people don’t often appreciate that until they hire a guy for a little less to save a few bucks and he doesn’t show up. Ends up costing them dearly.
  14. JB Sawman
    JB Sawman
    pennsylvania
    damm lucky and the old motto of be prepared no matter how much we cram on the truck sometimes you do not have exactly what is needed but you have something that will do glad you are ok crap happens fast JB
  15. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  16. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  17. stuckinthemuck
    stuckinthemuck
    How many operating hours without grease do you think caused that?
  18. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Prolly a couple days,these feed roll bearings are subject to huge loads
  19. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  20. Warner
    Warner
    E136330F-7C85-4771-9DF4-B81EC8AA8972.jpeg Found Mickey mouses club house.
