Whoops...
Discussion in 'Chainsaws and Power Equipment' started by SKEETER McCLUSKEY, Apr 3, 2018.
  1. WeldrDave
    To me, It looks like there was a weight issue up front ahead of the trailer pin coupling. Rivet fatigue, many years of flexing and floor issues payed into the demise on that thing. You can see some of the metal is Torn downward and others where the rivets are completely gone. Corrosion and metal fatigue there in my opinion. I've seen this on ships, many times!
  2. T.Jeff Veal
    I think the guy told me they had loaded a few pallets in the nose when it gave way...
    Screwloose and WeldrDave like this.
  3. WeldrDave
    Probably! Most likely very heavy stuff also.
    Screwloose and T.Jeff Veal like this.
  4. T.Jeff Veal
    1.25-1.5 tons per pallet.
    Screwloose likes this.
  5. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Was this loaded without being hooked up?
    Screwloose, M2theB and T.Jeff Veal like this.
  6. T.Jeff Veal
    I'm not sure. I know they do load some like that, but use the jacks under the front when they do.
  7. Warner
    Warner
    Nail bender buddy that I trade labor with just called saying his truck died going down the road. Pos Chevy that should have been replaced years ago…anyhoo said it would crank not start. My first thought is the fuel pump quit. Told him to crawl under and wack the tank a few times Hail Mary but works sometimes. He called back and said when I bang on the take it sounds hollow. That’s because your out of gas silly! He said the idiot light didn’t come on. Lol. Dude drives around with it on so much the bulb burnt out! He is going to hear about this for a while! :rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
  8. Warner
    Warner
    16A2F116-20C6-4898-A7A3-473FF1EF3915.jpeg This one month old tire was 1200$ CC29F52E-4F6E-4886-A043-9143F5466320.jpeg lifts are in!
  9. T.Jeff Veal
    Screwloose, Chvymn99 and JB Sawman like this.
  10. JB Sawman
    JB Sawman
    pennsylvania
    Getting the vehicles off the ground is easy compared to myself getting off the ground after setting the jack or laying on the creeper :rofl: :lol: JB
  11. Warner
    Warner
    Yes sir, everyday is an adventure!
  12. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Is that another way of saying with this batch of drivers they are your job security?
  13. Warner
    Warner
    Sure. Or I never know what I’m going to walk into in the morning.
  14. chris
    chris
    SE WI
    I have noticed that gravity has increased 10 fold over the last few years. The floor has gotten further away also. Then there is this ? that puts tools away where i can't find them ( mostly in plain sight). Have you noticed that 8mm sockets are very similar to 10mm sockets in that they magically vanish?
  15. JB Sawman
    JB Sawman
    pennsylvania
    I do believe I have noticed the same thing happening must have something to do with climate change :rofl: :lol: I am sure that it has nothing to do with getting older because I am only 30years and 360 months old:DJB
  16. JB Sawman
    JB Sawman
    pennsylvania
    Warner may sound like a strange question but are those lifts capable of being used outside ? I am considering getting one but I have to put outside as I do not have a high ceiling in my shop and I was going to just put a overhang over it JB
  17. JB Sawman
    JB Sawman
    pennsylvania
    I wish I could say nothing but a customer came in last night complaining his saw had been running good then it stalled and would just start than stop right away I opened the fuel cap and it was empty I put fuel in it and it ran fine his exact words were I THOUGHT IT HAD FUEL IN IT BUT I DID NOT CHECK!! :headbang::doh: JB
  18. Warner
    Warner
    I have often thought about pouring a pad and just put a lift out in the open. I have seen them set up like that. I would be concerned about corrosion. But, if it’s undercover I would think you would be ok. I’m fairly comfortable using the “rules” loosely. But, it will be holding a vehicle over your head so it might be best to consult a pro installer.
    Outdoor Car Lifts: Can You Do It? : Eagle Equipment
  19. JB Sawman
    JB Sawman
    pennsylvania
    I talked to the one rep and the specs are pretty straight forward about the pad specs and I always lean to the overbuilt anyway the one I was looking at was @4000.00 10000# lift but they did not recommend it for outside install electrics were not weathertite but their tech rep said if I was to cover with a overhang it would be ok but I was just curious it is a next year project JB
    T.Jeff Veal and brenndatomu like this.
  20. Warner
    Warner
    9A68553E-CFD5-459D-A834-49422E0030C1.jpeg All it took was a half inch of snow!
    Not my car.
