Whole house humidifiers
Discussion in 'Everything Else (off topic)' started by Well Seasoned, Nov 16, 2017.
  1. raybonz
    raybonz Moderator
    Carver, Mass.
    We use this product.. It's a bit less expensive and has lasted a year so far..We use this product.. It's a bit less expensive and has lasted a year so far.. Available at Lowes..
  2. raybonz
    raybonz Moderator
    Carver, Mass.
    Wondering why I can't post links here?
  3. bogieb
    I don't know, how about this
  4. raybonz
    raybonz Moderator
    Carver, Mass.
    It's strange.. I can post pics and text but not links.. Tried this on IE and Firefox and it will not post a link..
  5. HDRock
    That is strange I don't know why it would be , I use Chrome
  6. bogieb
    I'm using IE. Hmm, weird that it doesn't work for you. However, a work around is just to past the link in as text and anyone interested can copy it and paste it into their browser.
  7. Chaz
    Chaz
    Southwestern NY
    We went to a small filterless system this year as the cost of the filters in the large humidifier got to be a nuisance.
    We have very hard water, and would go through the filters quickly.
    The larger system put out more moisture.
    We're hovering around 22% humidity with the small system and a pan of water on the stove.
    Chvymn99, bogieb, bear 1998 and 3 others like this.
  8. Mwalsh9152
    Mwalsh9152
    Pelham NH
    Pretty sure that my humidifier is the cause for my mold problem in the attic. It totally soaked the plywood on the roof.
    Little bit of an issue with poor sealing up there to be fixed.
    bogieb, Chaz, HDRock and 1 other person like this.
  9. raybonz
    raybonz Moderator
    Carver, Mass.
    Home Depot works fine.. Can't even use the other stores name even if I quote when replying.. Very strange!
  10. raybonz
    raybonz Moderator
    Carver, Mass.
    WOW that's very bad! Mold is toxic and expensive to abate...
  11. raybonz
    raybonz Moderator
    Carver, Mass.
    Does your attic have proper ventilation?
  12. Mwalsh9152
    Mwalsh9152
    Pelham NH
    Absolutely. I did some investigating, and found the stuff the pros use. Gonna kill it once the attic dries out.
    I'll be ripping up the plywood floor and insulation in the spring and sealing the 2nd floor ceiling after that
    bogieb, Chaz, HDRock and 2 others like this.
  13. Mwalsh9152
    Mwalsh9152
    Pelham NH
    It has soffits and a ridge vent, but it will likely need a fan as well.
  14. HDRock
    Oh , I see , That's really weird
