Whole house humidifiers
Discussion in 'Everything Else (off topic)' started by Well Seasoned, Nov 16, 2017.
  1. Well Seasoned
    Ahhhhhh, after years of debating on purchasing one of these, I finally pulled the trigger.
    Picked up a large room to whole house humidifier. Only been plugged in for an hour and it's raised the humidity 3%. Is real cold out and the wood stove has been cranking, so the humidity is low 20s. I'll review this aircare humidifier in a couple days.
    raybonz, Marvin, J. Dirt and 5 others like this.
  2. HDRock
    J. Dirt and Well Seasoned like this.
  3. Locust Post
    So I ran the one I posted on the first page of this thread all winter last year and have been using it this year now as well. It has done a great job and still on the original wick. Add a half a cap of bacteriostatic every other fill.
  4. HDRock
    You must not have hard water
  5. Well Seasoned
    Review on the aircare humidifier after almost a week.
    Simple to fill, filling the 1.25 gal jug, this fills the base, then fill the 1.25 gal jug again, which is what I go through every 12 hours or so. The entire tank will easily last 24 hours, but this depends on the fan speed.
    The unit has quite a few fan speeds, but i keep it on auto. If the humidity goes down enough, the fan speed goes up and vice versa.
    There is an online humidistat about 4" away from the unit on the 6ft power cord, but it seems the readings are naturally high.
    The unit does a nice job bringing up the humidity in the house. When the stove is really cranking, humidity naturally goes down, thus the fan speed really increases for a bit, but it's kinda loud- similar to a large window AC unit fan sound.
    We've already noticed less dry skin, same for the dogs, less dry nose and throat, and a warmer comfy feel to the house.
    Not enough time to see how the wick performs, depends on environment, water quality, etc. I'm planning on buying a second one to swap out when needed, while soaking the original one in a solution, maybe vinegar & water & let dry.
    I'll keep reviewing as time passes.
    Chaz, raybonz, bogieb and 1 other person like this.
  6. HDRock
    I think they are worth the investment .
    I run mine on medium , Hi is just too noisy for me.
    I tried cleaning a filter And it went limp on me , Maybe I didn't do it right , a lot of lime in my water
  7. Well Seasoned
    I'll try it, and hopefully it doesn't go limp. Costs to much to continuously buy new ones.
    Chaz, raybonz, bogieb and 2 others like this.
  8. HDRock
    I snatched up 2 pack of filters from Amazon for $11 , Now I can't find them they want 14,99 for one :picard:
    I don't pay much attention to The reading on the unit, according to my other sensors That Reading is about 8% high
    Chaz, raybonz, Marvin and 2 others like this.
  9. Well Seasoned
    Thanks buddy!
    Chaz, bogieb and HDRock like this.
  10. raybonz
    raybonz Moderator
    Carver, Mass.
    Have the same one and it works great! Bought it used for a great price! I add the antibacterial additive to every tank and it has worked very well!
  11. raybonz
    raybonz Moderator
    Carver, Mass.
    Wow a 2 pack for $11.00 is a bargain! I would have bought them at that price right away!
  12. HDRock
    I did buy a 2 pack for $11 , I'm using one right now, If I had known the price was going to go up to 15 bucks for one I would have bought More of them right then
  13. HDRock
    The ones I bought at Sears cost me 17 bucks
  14. raybonz
    raybonz Moderator
    Carver, Mass.
    $14.99 each at Amazon right now.. If they go to 1/2 this price I will jump on it!
    Chaz, bogieb, HDRock and 1 other person like this.
  15. HDRock
    Found these That fit in mine , With the Reinforced aluminum , Might be able to clean them and reuse them , I don't know how much it means really but they have 5 stars on them
    Chaz, bogieb, Marvin and 2 others like this.
  16. raybonz
    raybonz Moderator
    Carver, Mass.
    Interesting.. I like the added aluminum mesh idea.. They are really fragile!
  17. Well Seasoned
    What's this solution you get? What does it do?
  18. HDRock
    Helps Prevent bacterial formation, And helps to cut down on Lime and iron accumulation on the wicks.
    You don't want bacteria forming in the wick And blowing out in the air
    Chaz, Well Seasoned and bogieb like this.
  19. bear 1998
    bear 1998
    S.C.Pa
    We have an Air Care also...it has a 3 speed fan w/ auto setting. Humidity adjust from 25-65% humidity....2 tanks (about 2 gallons each)....Air Care has a solution you can add to water in ur tank to prevent mold,bacteria,etc. We use a capful to 1 tank when refilling(we dont put it in every fill)
    They say the colder it gets....you want to lower your humidity setting...if not your windows n home will possibly sweat (mainly windows) we keep the house (depending on outside temps) 35- 45% hum.
    We'll use 3-4 gal. in a 24 hr period...depending.
    Chaz, HDRock, Marvin and 3 others like this.
  20. bear 1998
    bear 1998
    S.C.Pa
    Heres the solution for bacteria n such like HDRock. was sayin also....Amazon is a good place to get filters n solution...especially if you have prime (free shipping)....
