WHOA! Ideal Steel WOOOOMF
Discussion in 'Modern EPA Stoves and Fireplaces' started by golf66, Mar 3, 2023.
  1. NVhunter
    NVhunter
    Northern Nevada
    Sounds like a he'll of a back buff... I usually get them if the air is turned way down and there's no active flames. The off gasing from the slow burning wood builds up in the firebox and once it reaches a combustion point (either hits a flash point) or more oxygen is added BOOM as sudden explosion of flames which causes the WOOOFH sound and flames. Every time I get it I smell smoke that has been pushed out of the stove and can usually tell what the problem is even without hearing or seeing it.
    oldspark, Gark, Horkn and 2 others like this.
  2. Gark
    Gark
    SW Michigan
    Ok so my procedure here on the IS has almost totally eliminated those back-puffs:
    Sled-open on reload, intake full open until magnetic thermo top of stove is 300•. Close sled (engage cat). Wait 5 minutes. After 5 minutes, slide intake lever to half-open. Wait 3 minutes. After those 3minutes, slide intake lever to 1/4 open. Wait 3 minutes then slide wherever you want it to cruise for the next 10 hours.
    The take-away from this is that closing her down slowly & gradually gives the burning splits time to that slow burn coaling phase.
  3. Canadian border VT
    Yeah just too much fuel like a back fire in an old car with carburetors
    brenndatomu, Horkn and Softwood like this.
  4. Eckie
    Eckie
    How many "air options" does the IS have? I was surprised to look at my buddies fireview...tiny little air control compared to the AS. AS looks bout like a big rig stick shift.
    RGrant, brenndatomu and Horkn like this.
  5. golf66
    golf66
    great advice.
  6. oldspark
    oldspark
    NW Iowa
    Another variable is how you load your stove, how tight its packed, east west, north south, density of wood and of course moisture content.
    Chimney length, did i forget any?
  7. Canadian border VT
    Draft
    FatBoy85, Gark, brenndatomu and 2 others like this.
  8. oldspark
    oldspark
    NW Iowa
    Chimney length for draft, the fire tender can mess up the works.
  9. golf66
    golf66
    • how tight its packed: reasonably tight but noth a monolithic block of wood
    • east west, north south: east west
    • density of wood and of course moisture content: 3 year old CSS read oak. Need to get the moisture meter for an exact reading, however, this stuff is dry. Splits the size of a deck of card will light with a piece of Super Cedar, no kindling needed
    • Chimney length: Need an exact length but it's probably too long. There are two 90-degree bends in the venting system, one in the stove pipe and then the though-wall thimble where the chimney pipe transitions from horizontal to vertical. I added extra chimney pipe to make up for the two 90 degree bends. This thing drafts hard when its extra cold out. A stove shop recommended replacing the 90-degree bend in the stove pipe with a combination of 45's, however, it never got done.
    FatBoy85, Gark, brenndatomu and 3 others like this.
  10. oldspark
    oldspark
    NW Iowa
    Looking at what u posted I'm kinda surprised it acted that bad, maybe strong draft can make it worse under some circumstances.
    brenndatomu likes this.
  11. Oldhippie
    Oldhippie
    Ashby Ma
    Then I call it Ghost Flames. :)
    NVhunter and moresnow like this.
  12. FatBoy85
    FatBoy85
    Washington State
    Sounds like your 90 ⁰bends might be an issue here. With those bends, the draw in your chimney not being a straight shot, air gets stuck in there. Any way to take out the bends? I know this isn't likely to be changed but could help greatly.
    golf66 likes this.
  13. Hoytman
    Hoytman
    OH
    I’m wondering if it isn’t being caused from activating the CAT before all the wood has fully charred? Then again, the CAT should love the smoke.
    Might think about adding some weight to the top of the stove, or a latch of some sort that will only allow it to open so far. Don’t want it staying fully closed because that allows pressure to build up that could blow out the glass with a strong backpuff such as the OP had.
    This is always possible when burning the black rocks which why we like to have secondary air vents open until volatiles burn out of black rocks. Typically this doesn’t usually happen burning wood, but as you can see from the OP’s description, it is still possible. Just another reason to always open and close doors and vents slowly…when burning coal or wood.
